gt3582r
Old Dec 22, 2008 | 06:12 PM
adam00's Avatar
Default gt3582r
what the highest whp someone has made with this turbo on 2.0 GSR
Old Dec 22, 2008 | 06:59 PM
SD_Lurker's Avatar
HT White Ops
Default Re: gt3582r
I have seen a little of 700 on a t3 GT35R.....
Old Dec 22, 2008 | 09:18 PM
TheShodan's Avatar
Moderator
Default Re: gt3582r
And that was for a split second. not even the level to gauge such a turbocharger. What power level are you looking for? that would have been the better question to ask.
Old Dec 23, 2008 | 02:37 AM
adam00's Avatar
Default Re: gt3582r
im looking for something that will make a lot of power high boost and something that will make good power on low boost with out that much lag
Old Dec 23, 2008 | 03:22 AM
SD_Lurker's Avatar
HT White Ops
Default Re: gt3582r
What's a lot of power? What's good power on low boost?
Old Dec 23, 2008 | 05:39 AM
adam00's Avatar
Default Re: gt3582r
like 650whp high boost and 350whp on 10psi
Old Dec 23, 2008 | 07:24 AM
TiAL's Avatar
Default Re: gt3582r
you're going to be pushing the crap out of the 35 to get 650whp
350 on 10 psi would be easy
Old Dec 23, 2008 | 09:32 AM
adam00's Avatar
Default Re: gt3582r
what would be a better turbo also this would be in a street car
Old Dec 23, 2008 | 10:13 AM
Scheizty's Avatar
Default Re: gt3582r
Aren't we all? With turbos, the efficiency range is not that big. Because of this, you either select a turbo for a low boost application and run it out of efficiency when you crank the boost, or you get a good turbo with lots of power at the top, and get crappy efficiency when you turn down the boost. In one hand, you get good spool, on the other, you get huge top end. Know your hp goals, and depending on what you plan to make, you'll have to sacrifice some spool time to meet it. Unless you want to get two different turbos. Although a vaiable-geometry turbo would be sick.
based on your hp goals, a gt40 can handle that hp, but you can't expect it to spool like a gt28.
Old Dec 23, 2008 | 05:14 PM
spoolin turbo s's Avatar
Default Re: gt3582r
what about a s362?
seems like it would fit that criteria
i would either do that or a 35r
i just think a 40r would be a bit much on a street car
Old Dec 23, 2008 | 06:32 PM
TheShodan's Avatar
Moderator
Default Re: gt3582r
This is sanctified testimony. You cannot get all in one application. It just won't happen, especially with the displacement (under 3.0 litres) that we deal with. Even the S362 can't do it all that this OP is asking. He needs to be a bit more realistic as to the goals that he's trying to achieve, even if it means riding in a few more higher powered Hondas. That might help him a bit more with looking towards his needs. If the engine is built well enough, low boost/hi boost, won't really matter because he will be prepared for it through tuning and the right supplemental parts.
Old Dec 23, 2008 | 06:52 PM
fishieman's Avatar
Default Re: gt3582r
650 whp for a street car. Are you gonna be driving around in slicks all year round?
Old Dec 23, 2008 | 10:09 PM
ONE*SICK*FERIO's Avatar
Default Re: gt3582r
sorry off-topic is this gt3582r same as t3/t61 satge 5 ??
im running the t3/t61 "TE61" pushing 390hp but if i hit the gas cant hook up my tires falken(r-615)
1st-2nd-3rd lil bit, once i get traction its too late i lost the race...
cant imagine running 650hp driving around reading vaccum all the time LOL,
or did u mean street car just to be able to get the license plate but barely drive on the streets...?
Old Dec 23, 2008 | 10:46 PM
InDub's Avatar
Default Re: gt3582r
IMO, its not unrealistic at all..
I absolutely loved my 35r setup! I mad just a tad over 700hp maxing out my 3bar. I unfortunatly dont have any low boost data since I always drove my car on kill and on race gas
I gaurentee you will love the 35r setup though! Or at least I did. Of course it will also depened on the manifold, engine program, tune up, etc.
Here are some vids you can see, this is my old thread.
https://honda-tech.com/forums/showth...5249&highlight=
1sicef9
Dec 1, 2009 07:21 AM
R3JEKT
Feb 1, 2008 10:39 AM
EJ8 GSR-T
Oct 26, 2006 01:21 PM
not2slo128
Jul 25, 2006 03:24 PM
mugentype-r
Nov 2, 2005 01:42 PM
