GSR turbo the T3 burner?
I was just in a discussion about how a t3 47 trim is too small for a GSR. I heard it said that the high revving vtec motor will actually burn the t3 fairly quickly. How accurate is this guys? thanks
Moderator
Re: GSR turbo the T3 burner? (HondAcura)
This all depends on what you're trying to accomplish here. Just saying its bad is a matter of perspective. Are you trying to get a certain Torque at a certain rpm? Or are you trying to be the standard norm of about 250-300whp? If the latter is the case, then yes, it is rather made for building torque at a lower rpm band, not for all around use where it can effectively use the the 2nd set of lobes and good flowing VTEC head..
