GSR Turbo
Old May 1, 2008 | 08:44 AM
EGLUVN's Avatar
Default GSR Turbo
OK I got a 92 cx with an obd1 gsr.
Precision Turbo
Blox Cast manifold
Tial 38mm wastegate.
s300
what spark plugs do i need to run
Old May 1, 2008 | 09:09 AM
PHDZINE's Avatar
Default Re: GSR Turbo (EGLUVN)
NGK's.......
More info would help alot. Power goals etc.
Old May 1, 2008 | 10:17 AM
EGLUVN's Avatar
Default Re: GSR Turbo (PHDZINE)
300 wheel on 8 pounds. its got rc 440s 255 fuel pump wideband s300 precision sc61 dave hickman portmatched intake manifold and throbble body.
Old May 1, 2008 | 10:19 AM
chimmike's Avatar
I wouldn't go any colder than NGK BKR7E's if you want to run copper.
I recommend iridium for the simple fact that you won't have to change 'em every 3 months like you will copper.
Old May 1, 2008 | 01:00 PM
Schister66's Avatar
Man U FTW
Default Re: GSR Turbo (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote"> NGK BKR7E. </TD></TR></TABLE>
I've run them for 2 years and they work just fine. You do have to change them about every 2 months or so, but its not a big deal...they're like $1.25/each
Old May 1, 2008 | 01:26 PM
95 civic turbo_gsr's Avatar
Default Re: GSR Turbo (Schister66)
i run the NGK BKR7E's. they seem to work fine, and they are way cheaper then iridium plugs...
Old May 1, 2008 | 05:09 PM
Evilparadize's Avatar
Default Re: GSR Turbo (95 civic turbo_gsr)
If I choose to go with Iridium plugs, what kind would be recomended for a B16, Garrett T3/T04B Stage 3 Wheel Turbine A/R .63 & H-3 Trim Compressor A/R .70, 550 RC's and 300-350WHP?
Old May 2, 2008 | 10:33 AM
EGLUVN's Avatar
Default Re: GSR Turbo (Evilparadize)
so the ngks are good plugs but have to be replaced farely frequently?
Old May 2, 2008 | 10:37 AM
Schister66's Avatar
Man U FTW
The NGK's are fine and i generally replace them every other oil change just to make 100% sure that my car is in tip top shape. I'm sure you could run them longer...
Old May 2, 2008 | 12:15 PM
dpetro1's Avatar
Default Re: (Schister66)
i also suggest the regular copper BKR7E, but if you really want iridium they are BKR7EIX stock# 2667
Old May 13, 2008 | 11:23 AM
EGLUVN's Avatar
Default Re: (dpetro1)
ive gone to all the parts stores in town and nobody can get them. where do u get them
Old May 13, 2008 | 11:33 AM
chimmike's Avatar
Default Re: (EGLUVN)
dude, any parts shop that sells NGK can get 'em. If they tell you they can't, they're being super lazy.
http://www.sparkplugs.com
Old May 13, 2008 | 12:33 PM
dpetro1's Avatar
also you need to know the stock# not the actual part#
bkr7e stock # is 6097
bkr7eix stock# is 2667 as stated earlier
and pretty much any autoparts store stocks all of these plugs on the regular you shouldnt be having any trouble
Pnoyej6
Feb 1, 2007 07:48 PM
donkiman
Nov 7, 2004 06:11 PM
PrecisionH23a
Sep 29, 2004 08:22 AM
patdemps
May 25, 2004 06:08 AM
MrCrx
Apr 30, 2004 11:53 AM
