breather ports
Old Aug 17, 2007 | 05:05 PM
slickvic's Avatar
Default breather ports
hey i was wondering where can i buy the breather ports that go on the back of honda blocks. i believe they are off the z10 car that older preludes. thanks
Old Aug 17, 2007 | 06:42 PM
nitroice40's Avatar
Default Re: breather ports (slickvic)
I took my stock ones out and drilled holes in them. Then I welded steel -10 bungs on them. Only $10 each from Summit.
Old Aug 17, 2007 | 07:31 PM
SD_Lurker's Avatar
HT White Ops
https://honda-tech.com/zerothread/2022061
He sells them. Check out the link!
Old Aug 19, 2007 | 02:52 AM
B2uce's Avatar
ive got a pair if you want em bought from Honda never fitted tho, u in the uk?
Old Aug 20, 2007 | 04:59 PM
slickvic's Avatar
thanks guys for replying but are there any other ones
Old Aug 20, 2007 | 05:39 PM
XSIintegra's Avatar
Go with B&R Fittings...You will not be let down
Old Aug 20, 2007 | 05:48 PM
Bailhatch's Avatar
Default Re: breather ports (nitroice40)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitroice40 &raquo;</TD></TR><TR><TD CLASS="quote">I took my stock ones out and drilled holes in them. Then I welded steel -10 bungs on them. Only $10 each from Summit.</TD></TR></TABLE>
if you're on a budget or dont want to wait, you could buy those at a local hydraulic shop or NAPA for less than half that. Just ask for JIC fittings
Old Aug 21, 2007 | 04:22 PM
slickvic's Avatar
i tried emailing and pm b&r fitting but no response
Old Aug 21, 2007 | 06:35 PM
B R Fittings's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slickvic &raquo;</TD></TR><TR><TD CLASS="quote">i tried emailing and pm b&r fitting but no response</TD></TR></TABLE>
I sent you a PM yesterday with the price. They are $45 shipped to the lower 48 states. I never received an email.
bandrfittings@gmail.com
Thanks
MidShipCivic
Welding / Fabrication
Jan 29, 2008 06:28 PM
Spence
May 18, 2005 04:41 PM
h22a193
Aug 17, 2004 07:26 PM
N1NjA TuRtLE
Nov 16, 2003 11:51 AM
Chris EK
Jun 25, 2003 01:32 AM
