crankcase vent w/boost
Old Jan 6, 2003 | 01:24 PM
Bongnak's Avatar
Default crankcase vent w/boost
wont you loose boost pressure through the crankcase vent on the vavlve cover if you dont have a cath can?
Old Jan 6, 2003 | 01:28 PM
JM Performance's Avatar
Default Re: crankcase vent w/boost (Bongnak)
no, pcv valve closes w/o vacuum.
Old Jan 6, 2003 | 03:25 PM
Bongnak's Avatar
Default Re: crankcase vent w/boost (00SilverLS)
yeah but the tube that connect from the valve cover to the intake tube or charge pipe right before the tb....is there a one-way valve there somewhere also?
Old Jan 6, 2003 | 04:09 PM
the tube from the valve cover should not be connected to the intake after the turbo. either connect it before the turbo, or better, add a valve cover breather filter.
Old Jan 6, 2003 | 04:20 PM
FrankandTim's Avatar
Old Jan 6, 2003 | 06:23 PM
Stewie's Avatar
Default Re: crankcase vent w/boost (Stevo)
A crankcase vent attaches to the the block, not the valve cover.
JK with the
Old Jan 6, 2003 | 07:12 PM
JT's Avatar
JT
Default Re: crankcase vent w/boost (Mac8008)
It depends on the design of the engine, PCV (positive crankcase ventilation) can be located on the block or on the valve cover. crankcase vapor can pass through the valve cover through the oil galley passages in the cylinder head. That's how oil drains down to the crankcase.
Old Jan 6, 2003 | 07:33 PM
crxhybrid1320's Avatar
Default Re: crankcase vent w/boost (JT)
Im using a catch can which connects to the valve cover vent
and also to the PCV in the back of the block.
Old Jan 6, 2003 | 07:37 PM
Default Re: crankcase vent w/boost (crxhybrid1320)
yeah, that doesn't do much of anything. the valve cover is where air ENTERS the crank case. Seeing how there isn't any oil in the air to catch, it isn't doing much. If you are catching oil, that means your getting blow by gas and your rings might be going.
Old Jan 6, 2003 | 07:42 PM
the oem tube goes from the valve cover to the intake tube. the air from the intake tube sucks the pressure out of the valve cover i thoght.
Old Jan 6, 2003 | 07:45 PM
you have it backwards. the tube from the intake manifold sucks air from the crankcase (through the pcv). the valve cover is just an inlet. it should be setup like this:
Old Jan 6, 2003 | 07:49 PM
So it sucks through the intake tube goes through the oil passages and out the pcv for circulation.
Old Jan 6, 2003 | 07:55 PM
yep.
Old Jan 6, 2003 | 08:17 PM
evoeone's Avatar
mine was on the head, not block, just left a piece of hose on it, ghetto style
Old Jan 6, 2003 | 09:07 PM
b16ahybrid's Avatar
Default Re: crankcase vent w/boost (evoeone)
flow of the air goes from the intake through the hose and into the valve cover......
Old Jan 7, 2003 | 02:50 AM
FredoSP's Avatar
never knew that
Old Jan 7, 2003 | 04:44 AM
xci_ed6's Avatar
Default Re: crankcase vent w/boost (FredoSP)
That pic looks wrong.
The intake tube has a higher preassure than the intake manifold, so the air is pusher through the valcve cover, through the head, through the block then through a really shitty filter, the output from that filter is conected to the PCV valve which then conects to the intake manifold after the throttle plate.
If I were to add a catch can I think the most productive place would be between the stock filter and the PCV valve.
-Dustin
civic-steve-94
10
Jun 12, 2011 05:05 PM
raysjdmh22a
Oct 24, 2006 03:35 PM
huge230
May 12, 2006 12:47 PM
honda95civic
Feb 5, 2005 01:41 PM
spencer00si
Sep 6, 2002 01:46 PM
