GSR boost issue?HEEELP
Old May 12, 2009 | 04:35 PM
Wyzdum's Avatar
Default GSR boost issue?HEEELP
I have a GSR swap boosting 15 lbs on spring...i have low compression pistons 9:1 ...50 trim turbo ....SO HERES THE ISSUE ...out of the blue my car starts running beautiful!! hard 15lbs no boggin then i think i lifted my head because i was running stock headstuds ...the car started to run like shyt. so i bought arp headstuds installed them.car ran better for about a day then it just stopped boosting... wtf! no charge pipes blew off ,all clamps are tight ,no visible cracks or leaks ...BUT ALSO NO BOOST...im lost lost lost what can it be? sorry if my description was all over the place ....its just i cant figure this issue out!
Old May 12, 2009 | 04:39 PM
omgwtfbbq's Avatar
Default Re: GSR boost issue?HEEELP
run a boost leak test. Even if the clamps are tight, you could still be losing boost.
Old May 12, 2009 | 04:41 PM
redlinetuning's Avatar
no boost? just no boost to your boost gauge or no boost from your turbine? when you installed your headstuds, did you torque them down properly with the molylube? check your compression. What wastegate are you using? 15lb spring? What is your EMS?
Old May 12, 2009 | 04:49 PM
Wyzdum's Avatar
turbonetics delta gate wastegate...i just saw black marks by where the wastegate meets the manifold like a exhaust leak....no boost at all to gauge or from turbine...im runnin a chrome basemap
Old May 12, 2009 | 04:51 PM
Wyzdum's Avatar
headstuds done right! torqued to 80 lbs w lube
Old May 12, 2009 | 05:04 PM
if it's black, it's leaking. fix that first.
Old May 12, 2009 | 05:41 PM
Wyzdum's Avatar
some1 said it might be stuck open ...im goin to unplug the vacum line from the wastegate n give it a drive see if it builds boost..ill keep u guys posted thnx
turbo-crx
Jan 24, 2009 09:06 AM
zbower7
Aug 4, 2004 09:31 AM
Andrew 825SM
Oct 2, 2002 07:39 PM
Mr. Softee
Jul 8, 2002 06:54 AM
Thrillhouse
May 16, 2002 10:00 PM
