greddy type s bov question
Old Apr 30, 2010 | 05:09 PM
sc34dc4's Avatar
Default greddy type s bov question
I bought this used and just wanna make sure it's working properly. I've searched on here but never got a clear answer. Anyways when the car is at idle is the valve supposed to be open a little "like in the pic" or should it be completely closed? When throttle is pushed the valve pushes down and closes. Then when throttle is lifted it goes back up and releases air. I'm assuming this is how it should work. Also I keep reading about adjusting it. Mine flutters under light boost but sounds normal under full boost. 12.5psi
Last thing has anyone ever done the single spring mod. I saw it online and a lot of evo guys do it but I don't know the benefit of it "if any" so I'm trying to figure it out. Would it be something worth doing to mine. Thanks in advance.
Old Apr 30, 2010 | 09:05 PM
sc34dc4's Avatar
Default Re: greddy type s bov question
Bump
Old May 1, 2010 | 09:44 PM
sc34dc4's Avatar
Anyone?
Old May 2, 2010 | 07:25 AM
HiProfile's Avatar
If you adjust it to be closed at idle (more spring pressure), that means it will actually open slower. People with factory turbo cars have done tests, and all bov's that stay closed at idle will lead to low-boost flutter.
You can hook that bottom nipple to pre-throttlebody boost. Combine that with more spring pressure, and it will stay closed at idle but still open when there is any boost left in the charge pipes.
Old May 2, 2010 | 02:47 PM
dpetro1's Avatar
everything looks/sounds like its working just fine. no need to make any other adjustments
jacob4lester
Feb 15, 2010 05:30 PM
sonne_side
Feb 20, 2009 09:54 PM
accord99power
Aug 20, 2008 02:36 PM
mattcalica
Dec 1, 2003 09:19 AM
Trigun
Nov 30, 2002 02:19 PM
