Greddy Turbo Kit question
Old Oct 4, 2002 | 06:37 PM
td04civic's Avatar
Default Greddy Turbo Kit question
Could the Greddy D series kit handle 15psi or should i be looking at another kit?
Thanks
Old Oct 4, 2002 | 06:46 PM
TheIntegraGuy's Avatar
Default Re: Greddy Turbo Kit question (td04civic)
The Greddy kit can, your motor won't....not unless you invest in some MAJOR mods for that D-series of yours.
Old Oct 4, 2002 | 06:49 PM
td04civic's Avatar
Default Re: Greddy Turbo Kit question (SiDESLiDE240)
Yeah i know. The motor is going to be built. Is it worth getting this kit or should i invest in a kit w/ a bigger turbo?
Old Oct 4, 2002 | 07:02 PM
FredoSP's Avatar
Did you ever consider using the $ for the turbo and maybe do a B18 swap??
Anything can be done, its a matter of how much $ you got
Old Oct 4, 2002 | 07:06 PM
td04civic's Avatar
Default Re: Greddy Turbo Kit question (FredoSP)
Please don't make it a sohc vs. dohc debate. It was just a simple question.
Will i make more power w/ a bigger turbo eg.t3/t4 at the same boost level or will it be the same w/ the td04h-15g?
Thanks.
Old Oct 4, 2002 | 07:27 PM
turboD16's Avatar
your not going to be making much power difference between 12-15 psi on a tdo4.
Old Oct 4, 2002 | 07:38 PM
td04civic's Avatar
Default Re: Greddy Turbo Kit question (turboD16)
Why would i not make power w/ the td04 between 12-15psi? Would a t3/t4 make a difference between these boost levels?
Midwestrider's Avatar
Thanks
What type of pwr you wanting to make? How much $$ you looking to spend?
If your goals are 200whp or so and one a budget get the greddy kit and ic..
Below are some old post of the ppl with the greddy kit w/ the dyno numbers.
https://honda-tech.com/zerothread?id=207551 <-- VTC_Slow_CiViC
https://honda-tech.com/zerothread?id=180690 <--JFK78
https://honda-tech.com/zerothread?id=146503 <-- Roaring Turtle
Hope that helps!!
Old Oct 4, 2002 | 07:41 PM
td04civic's Avatar
Default Re: Greddy Turbo Kit question (Midwestrider)
i'm looking to make 250whp on the d16z6. So you don't recommend the greddy kit?
Old Oct 4, 2002 | 08:19 PM
No...Personally, I think it would be better to swap it to a B-series so you get more base hp than a SOHC. And just put on a DRAG turbo kit and it should set you up at the top with the others...My point of view, not trashing on the singles, but what a SOHC can do, a DOHC can do better...and don't get a GReddy kit...DRAG or custom.
Old Oct 4, 2002 | 08:56 PM
bretx0r's Avatar
because the turbos so tiny it cant flow that much CFM
Old Oct 4, 2002 | 08:57 PM
bretx0r's Avatar
shut the **** up.
not all of us are made of money
and anyways. you could swap in a D16Z6 into ur car, invest in some pistons/rods blockguard standalone fuel management and at least a .48 comp .42 a/r t3 and with proper tuning youll be able to run over 15psi and be able to beat up on a stock B16, B18B, B18C turbo for way less $.
[Modified by bretx0r, 6:01 AM 10/5/2002]
Old Oct 4, 2002 | 09:06 PM
boostinb18's Avatar
Default Re: Greddy Turbo Kit question (bretx0r)
i dont think building a d16z6 will cost lkess then a b18b swap......but anyways the greddy tdo4h-15g is only good to about 220 hp and thats way past its efficiency! you'll need a big t3 or a smaller t3/t4 if you want 250 hp.
good luck!
Old Oct 4, 2002 | 09:30 PM
Default Re: Greddy Turbo Kit question (boostinb18)
shut the **** up.
Does somone have a language problem here?
I think you're over reacting, pal. I wasn't talking sh*t about the SOHC, but he said he was going to build it up. Building up engines cost $$$ my friend. Plus, he wants 250 WHP. With a GReddy kit, I don't think so. Also, I said "personally" meaning MY OPINION and HOW I THINK. Everything that you said is a wise choice. But that costs money just like swapping it with a B-Series and Turboing it. Think about it for a min homie. Maybe two. I think it would be much more reliable to swap it out and turboing it rather than building up the single and boosting the sh*t out of it. What would you rather have?
shut the **** up.
I never said that he was made out of money because who is? AND...Is someone watching a little too much Fast & Furious?
[Modified by SiDESLiDE240, 12:31 AM 10/5/2002]
Old Oct 4, 2002 | 10:22 PM
madman604's Avatar
IMO the Greddy kit is not good past 15 psi (wastegate limitation) also you WILL have to build the bottom end. there is a SOHC guy in the 10's but thats another story.
Expect around 200-220 HP on a stock bottom end w/BIG INTERCOOLER and proper fuel management.
If you want more power than that, seriously consider saving up for a B series swap instead. Then turbo that (like me)
BTW my motor was a D16Z6
Old Oct 4, 2002 | 11:38 PM
shadowdawn's Avatar
Default Re: Greddy Turbo Kit question (Turbo E)
I think you should go for a kit with a t3/t4 b turbo, they are best suited for 1.5-1.7 engines like yours.... of course the greddy kit IS a good kit, but your topping out the compressor efficiency at 250whp is my guess.... and the t3/t4b will kick your *** hard back into your seat when it hits :D
Old Oct 5, 2002 | 10:13 AM
td04civic's Avatar
Default Re: Greddy Turbo Kit question (shadowdawn)
Thanks for all the replys. The only reason i'm not swapping to a b series is that i like the d16 motor.
If i build a custom turbo kit where would i find the oil sending lines and the little misc. stuff that comes w/ it?
burge
Mar 7, 2007 01:16 PM
eg6ryder
Jan 24, 2006 07:33 PM
EMphaticONE
Nov 8, 2004 12:35 PM
civic5483
Jan 16, 2004 07:08 PM
Big_Bird
Oct 30, 2003 05:51 PM
