Greddy tpye s Help
Old Jun 19, 2010 | 03:06 AM
TURKISHFORCE's Avatar
Default Greddy tpye s Help
my greddy type s is quieter whereby i install new wastegate spring 1bar/15psi??
wen i adjust blow off soft the blow off valve is open idling mixture on like 900rmp
but noise (pffiiiiiiis) better to hear,not someone like prior???
earlier was noise in 0,3-0,4 (5-6psi) bar extremely louder
now sound cames like 0,7-0,8 bar 10psi??
also goes that wastegate noise ore turbocharger flatter/flutter not quite away /gone
the bolt /screw is quite open . no result? like flatter sound from turbo/wastgate ore trottlebody?
must close on without psi manifold pressure low rmp.
whats rong with that greddy type s.
my vacum line on the manifold ist strong maybe to strong??
mfg Turkishforce
I cut the spring and all again right
THE END
Old Sep 13, 2010 | 08:50 AM
Default Re: Greddy tpye s Help
i have this sound like the video
http://www.youtube.com/watch?v=jEUWE...layer_embedded
greddy blow off ist lowest ajust attitude
most i cut the spring little
Old Sep 13, 2010 | 01:46 PM
TheShodan's Avatar
Moderator
loosen the bolt at the top of the bov a bit. make sure you have a strong vacuum source that is not a part of anything else, and try again. What the sound is in the video is not good a at all.
Old Sep 13, 2010 | 11:46 PM
is complett soft triming on the top bolt
vacum line is on the manifold install on a strong vacum line .
info
http://www.evoxtuners.com/showthread.php?p=1544
maybe i take/make on spring mode???
accord99power
Aug 20, 2008 02:36 PM
b18c1Monster
Jul 4, 2005 03:17 AM
TUR3Ovtec
Dec 19, 2004 10:10 PM
APEXI Si
May 28, 2004 12:09 PM
Chip398193
Oct 2, 2001 09:00 AM
