Greddy Oil Feed Lines
Old Jan 10, 2003 | 04:20 PM
  #26
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (Hatchblack)
i tried searching for one, and could not find one for a TDO4. You could call hahnracecraft.com and ask them, they will probably know since they they work with Mistu. turbos.
Old Jan 10, 2003 | 04:27 PM
  #27
willyboyK20's Avatar
Default Re: Greddy Oil Feed Lines (DeepSi)
but the feed oil feed parts that u listed would work right?
Old Jan 10, 2003 | 04:48 PM
  #28
DeepSi's Avatar
Default Re: Greddy Oil Feed Lines (willyboyD16)
yeah all the parts for the oil feed line should work. The only part that differs from the oil drain line is the flange to connect to the turbo. You might want to check on the Oil Inlet Fitting, but i believe they are the same on all mistu turbos, according to Hansmotorsports.com website
Old Jan 10, 2003 | 07:21 PM
  #29
thanks
Old Jan 11, 2003 | 08:55 AM
  #30
DeepSi's Avatar
According to Turbocivic.net, the oil feed banjo bolt is Oil Pressure Hose Banjo Union, small male / female 10 X 1.24mm. i used 10 x 1.25mm. not sure what the 1.25 is for.
Old Mar 11, 2003 | 12:54 PM
  #31
inspyral's Avatar
thread pitch
Old Mar 11, 2003 | 01:01 PM
  #32
Boostless97Lude
Guest
Posts: n/a
Default Re: Greddy Oil Feed Lines (inspyral)
thread pitch
i'm lost, you brought this out of the archives for the words "thread pitch" :scratheshead:
Si-Yaaa!
Aug 4, 2005 11:20 PM
StolenTeg
Apr 15, 2005 09:38 AM
JPowers
Jul 17, 2002 09:38 AM
JPowers
Jul 11, 2002 08:15 AM
