greddy kit vs. jackson racing
Old Aug 24, 2003 | 01:11 PM
RICE POLICE SIP's Avatar
Default greddy kit vs. jackson racing
Hey guys i was just curious as to what you guys thought about this.... What would put down more power on a SOHC vtec engine... a complete greddy turbo kit or a jackson racing supercharger... Since they both boost around 6lbs would they very similar in power... also the tdo4 is a pretty small turbo so, i was just curious to know what you guys thought TIA..... oh and i'm not going for oh my god fast i'm just looking for a little more power and still street legal... TIA
SHANE
Old Aug 24, 2003 | 01:15 PM
big tool's Avatar
Greddy kits make pretty good power on a sohc as far as i know. JR will give you more low to mid power though the Greddy kit should make more power on the top end.
Old Aug 24, 2003 | 01:29 PM
Default Re: (pkoury)
thanks.. does anyone have dyno numbers of both? thanks
shane
Old Aug 24, 2003 | 01:33 PM
big tool's Avatar
someone post dyno #'s im interested as well at seeing the difference
how much are you looking to run shane, 6psi on either?
Old Aug 24, 2003 | 05:23 PM
Civiclx's Avatar
I wanna know too!
Old Aug 24, 2003 | 06:32 PM
scttydb411's Avatar
go with the greddy b/c you will be able to up the boost later very easily and run a fmic to boost safely.
if you are going jrsc...which will be fun, but you will have to replace the pulley and readjust the belt to up the boost. if you're going that route get one of the lht style jrsc. they come with a water to air intercooler in the intake manifold.
Old Aug 24, 2003 | 09:46 PM
Default Re: (scttydb411)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 &raquo;</TD></TR><TR><TD CLASS="quote">go with the greddy b/c you will be able to up the boost later very easily and run a fmic to boost safely.
if you are going jrsc...which will be fun, but you will have to replace the pulley and readjust the belt to up the boost. if you're going that route get one of the lht style jrsc. they come with a water to air intercooler in the intake manifold.</TD></TR></TABLE> do you have any info on the lht style superchargers? also i'm probably gonna buy it used.. and i'm only planning on boosting 6 lbs and that's probably about it... thanks and any dyno numbers would be great as well thanks
shane
Old Aug 24, 2003 | 09:51 PM
Kataku2K3's Avatar
Default Re: (92boostn'hatch)
Just my opinion but TURBO = superchargers = , because honestly, we just haven't had any good luck with them... Once your IAT gets above ~140 degree F you're screwed... With Jackson non intercooled units we've measured the IAT at over 200 degrees F... Just my $0.02 again... Good Luck
Old Aug 24, 2003 | 10:40 PM
PHiZ's Avatar
Default Re: (Kataku2K3)
^^^ listen to this guy, Ground Zero builds some nasty rides!
-PHiZ
Old Aug 24, 2003 | 11:11 PM
isn't there some kinna intercooler for the superchargers?
Old Aug 25, 2003 | 02:56 AM
oscarmayer's Avatar
I maxed my greddy kit out before I sold it at 250 wheel power. I used a greddy FMIC with it. But any ebay $250 fmic will work (ones that are made by someone not some starion one).. If you dont; get a fmic then you will be running 5 lbs on the stick kit. I knwo of a place that can get you the complete sohc greddy with the large fmic for like $2250+ shipping.
http://www.alamoautosports.com I got my kit from them long ago about 3 yrs ago actually. They are a large shop in texas and doo awesome work. They can help you with anything you need.
HP numers onthe kits.
stock greddy w/o fmic =5lbs 150 wheel power
greddy kit with fmic =7lbs 180-190 wheel power
If you want to go above 7 lbs I recommend you get a 255 intank fuel pump, a adjustable FPR a boost controller, and some prelude vt-ec injectors (vigora and nsx use the same injectors too) you can have the greddy blue box reprogrammed to run 10-12 lbs of boost as well. That woudl be good to like 220+ wheel power.
Old Aug 25, 2003 | 06:49 AM
VTC_CiViC's Avatar
Default Re: (oscarmayer)
Take a look at average dyno #'s. A stock SOHC with an intercooled GReddy kit can see 150whp +/- no problem, JRSC kits struggle to make 140whp with all the bolt-ons. As you up the boost, it only get's uglier for the JR unit. The blower used on the SOHC's is just too inept and develops ALOT of heat.. personally, turbo for me
Old Aug 25, 2003 | 08:40 AM
Default Re: (VTC_CiViC)
thanks guys looks like i'm going turbo.... AGAIN sign...
I:_Drive
Honda Civic (2006 - 2015)
19
Jul 13, 2007 10:48 AM
trooper0641
Sep 29, 2004 08:52 PM
-BlueGSR-
Apr 24, 2003 09:52 AM
YellowR2000
Feb 26, 2002 10:45 PM
