Greddy kit with no intercooler
Old May 19, 2004 | 10:39 AM
ih8danoles's Avatar
Default Greddy kit with no intercooler
Will I be alright running the kit with no intercooler for about a month or so? More importantly, will I have any problem driving 400 miles to TN without one (since the rpm's will be over 3,500 most of the time on the interstate).
Old May 19, 2004 | 10:43 AM
Vtec92Civic's Avatar
Default Re: Greddy kit with no intercooler (ih8danoles)
plenty of people run non intercooled setups, but it's just a better idea to get an intercooler for re-assurance, longer lasting setup, and it gives you a little more power since it lowers the air temp.
You'll be good just don't go ripping around a lot.
Old May 19, 2004 | 10:59 AM
Pengo's Avatar
honestly as long as you don't have a heavy foot and it isn't too hot that day, you should be fine. once your foot get sensitive to boost (which is where a boost gauge helps alot) you can cruise around easily without even getting into boost, even with the small 15g. once you get up to speed on the highway and maintain constant speed, you prob won't even be in boost so there isn't as much to worry about. i used to cruise for days on local roads without going into boost
Old May 20, 2004 | 07:04 AM
ih8danoles's Avatar
Default Re: Greddy kit with no intercooler (Pengo)
does anyone else have experience running with no intercooler? Does it make a notable difference when you do get one even at the same boost?
Old May 20, 2004 | 09:23 AM
TheShodan's Avatar
Moderator
IT makes a significant difference. not just in Power, but what it takes to get the additional power. Once the air temps start to drop, you can increase boost as much as 1 psi on that setup, and you will lower your chance of detonation when an intercooler is installed
rustydusty1717
Apr 19, 2008 05:47 PM
Arsenal
Oct 13, 2003 06:55 AM
blacksi00
May 15, 2003 08:46 PM
RiceBurner98SC
Jan 9, 2003 10:17 PM
boipika
Feb 26, 2002 10:16 AM
