Greddy FCU Question
Greddy FCU Question
I am in the process of finishing up my turbo project, and have the Greddy blue box completely installed, except for the MAP in and out. If I just go ahead and finish the install, will I be able to drive my car for a week or two before the turbo itself goes in, or should I just hold off on finishing the install.
Re: Greddy FCU Question (Secret Squirrel)
Well I just started the car up with the blue box installed, and it seems to be running fine. The small green LED is blinking, is that what it is supposed to do? Or is is supposed to stay lit?
without the map in and out connected, the blue boxi snt' making any fuel adjustments for your car. You are then basically running off the stock ecu fuel map right? WHy don't you want to connect it? ti's there for a reason.
blinking is fine. that means its working. having it hooked up should be fine since you're not gonna be getting outta vacuum it's not gonna be doing anything
Re: (spooned out)
Alright it is installed, and everything is working fine. As for the MAP on my 00' ex, it was a red and green wire, I believe. Here is a link to the wiring diagrams I used.
http://www.turbod16.com/viewtopic.php?t=625
Boosthead
01-05-2005 07:40 PM
