Greddy blue box?
Old Jun 17, 2004 | 08:25 AM
u_tal's Avatar
Default Greddy blue box?
Hello guy's
I want to buy greddy blue box and i want to know if it will be good for my D16 turbo ? and do i need something more with that? like: injectors, gm map sensor, fuel pump, fuel regulator? and how much boost i can ran with that unit?
And where i can buy it?
Thank you! From your far away friend!
Udi
ISRAEL
Old Jun 17, 2004 | 08:48 AM
dennis's Avatar
Default Re: Greddy blue box? (u_tal)
we run it on my friends d16 "junkyard" setup. Works fine for us. Stock injectors, stock map sensor, stock pump, stock regulator. We're running around 8psi, maybe a tad more with creep. Bought used off ebay , or here, can't remember. AFR pegged rich all the way to redline. My wideband should be getting here soon, so we'll see *how* rich we're really running...
Old Jun 17, 2004 | 09:17 AM
skierGT's Avatar
the blue box is ok. im running it. it keeps it real rich all the time under boost.
you dont need nething. it is made to run with stock injectors and stock fuel pump.
its easy to wire into the ecu and as far as boost i think it can support 13psi which is where the map sensors limits end. this is not to be confused with what a stock d16 can hold. i wouldnt go over 8 lbs on stock internals.
Old Jun 17, 2004 | 11:48 AM
u_tal's Avatar
Default Re: Greddy blue box? (skierGT)
o.k.... thank you guy's!!
Do i need missing link?
Thank you
Udi
Old Jun 17, 2004 | 12:41 PM
dennis's Avatar
nope...
Missing link is to keep MAP from seeing boost. As long as you don't boost over 11 PSI ( think that's what the stock map will read) you wont' get a CEL. I wouldn't even think about boosting over 11psi on stock D internals. Not to mention your fuel delivery isn't up to par either with just the blue box.
Old Jun 17, 2004 | 12:47 PM
u_tal's Avatar
Default Re: Greddy blue box? (dennis)
Yeh.. you right!
But what if i want to boost over 11psi something like 14 psi (i can risk the engine... i have a garage...)???
Old Jun 17, 2004 | 12:53 PM
dennis's Avatar
then you need a real engine management solution - and a 3bar map sensor, and injectors, and a fuel pump, etc. etc. etc..
Old Jun 17, 2004 | 01:22 PM
u_tal's Avatar
Till now i have been using AEM EMS for my customers, but i'm trying to find cheaper solution.. i don't have problem to use big injectors or high flow fuel pump or 3 Bar map sensor actully i have been do it till now ... just want to find cheaper way to run 14 psi....
Do you have some kind of solution?
Thank you
Udi
Old Jun 17, 2004 | 02:32 PM
MachAF's Avatar
uberdata... its free
Old Jun 17, 2004 | 03:22 PM
u_tal's Avatar
Default Re: Greddy blue box? (MachAF)
Yeh... but i didn't understad what i need to buy for tune the car(eprom burner, emulator?)...
Old Jun 17, 2004 | 11:50 PM
Sketch_hs's Avatar
throw the blue box off a cliff and get REAL engine management y0!
Old Jun 18, 2004 | 04:44 AM
EKB18BPR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">uberdata... its free</TD></TR></TABLE>
HUH?! **** get me one...how can i get a fuel management for free?
Old Jun 18, 2004 | 05:55 AM
fjt's Avatar
fjt
Default Re: Greddy blue box? (98B00STED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">HUH?! **** get me one...how can i get a fuel management for free? </TD></TR></TABLE>
The software you use to fine tune your car is FREE but the other stuff u will need to make it work its not(I.E. Chip burner,Chips etc...)
But it still way cheper than other Engine management sistems
Old Jun 18, 2004 | 06:26 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: Greddy blue box? (fjt)
stock 1bar map sensor limit is actually 10.5 psi
EX-T
Mar 29, 2006 12:45 PM
boostincoupe
Dec 16, 2005 02:13 AM
egizzle8
Sep 3, 2004 05:51 AM
skierGT
Oct 8, 2003 10:49 AM
TheIntegraGuy
Jun 16, 2002 10:19 PM
