Greddy Blue Box
Old Sep 23, 2001 | 07:35 PM
sporter's Avatar
New User
Default Greddy Blue Box
Just curiuos. I had my turbo kit professionally installed but for some reason I can't find the blue box that they supposedly installed. I know this is a stupid question but I don't trust this shop that much though it was already too late. Anways. If the blue box wasn't hooked up then I should be getting a check engine light when there is positive boost right? Or can you skip the box install and everything will run decent but not great?
Thanks
Old Sep 23, 2001 | 07:43 PM
PressurizedSi's Avatar
Default Re: Greddy Blue Box (sporter)
If the blue box was not connected it would not idle very good at all. The 310cc injectors would dump too much fuel for a smooth idle. Have you looked under the kick panel where the ECU is to see if something it connected to it? I would not recommend driving the car until you make sure the box is connected to the ECU.
Old Sep 23, 2001 | 08:53 PM
sporter's Avatar
New User
Default Re: Greddy Blue Box (PressurizedSi)
I have checked and nothing looks connected to it. Also this is the SOHC motor so i'm using stock injectors. I will give it a good look tommorow. I am wondering where my other 20 or so HP is. Had it on there for 6+mos now and now it's getting to me.
Old Sep 23, 2001 | 09:48 PM
turbo_b18c's Avatar
Where your 20 other HP is? HaHaHa...well you should ask the shop if they used the supplied "black" box or check valves.
Old Sep 23, 2001 | 10:04 PM
sporter's Avatar
New User
Default Re: Greddy Blue Box (turbo_b18c)
134whp is all I got! I expect another 20. So i'm thinking something isn't there. My compression is fine. Haven't done a leakdown though. Also that was with old fuel filter+cap+rotor. Since then I've replaced them and noticed maybe 2hp difference I was thinking I should be about 150whp or so. Not much. But 134? WTF?!
Old Sep 23, 2001 | 10:30 PM
liam821's Avatar
25 Year Member
what boost are you running? That is ~30hp over stock..but still..thats not much.
liam
bubskie
Dec 21, 2010 12:21 PM
cxjon
Dec 30, 2004 06:38 PM
This One
Jan 30, 2004 01:23 PM
1990hondaHF
Sep 27, 2003 08:43 AM
boostincoupe
May 20, 2003 03:29 PM
