Grainger Valve for adjustable boost..know how to do it??
Old Aug 11, 2002 | 01:48 PM
cjmech's Avatar
Default Grainger Valve for adjustable boost..know how to do it??
Does anyone know how to do this or have a link that explains more?? I did a search and found nothing.
Thanks,
Cj
Old Aug 11, 2002 | 02:06 PM
kawgomoo's Avatar
Default Re: Grainger Valve for adjustable boost..know how to do it?? (cjmech)
disconnect the vacuum line that runs from wherever to the wastegate. i imagine you are using a delta gate and only have the side port hooked up. so somewhere in the middle of that line, cut it, install the boost controller {grainger regulator} and go nuts. remember to set the boost controller all the way down {zero bleed} should be all the way clockwise. {dont quote me on that} when you put it in look for the words in and out on the controller....might have it might not. in will go to the manifold out to the wastegate.
its not rocket science. one full turn of the controller should yield a pound or two of boost.
Old Aug 11, 2002 | 06:05 PM
ion_four's Avatar
Default Re: Grainger Valve for adjustable boost..know how to do it?? (kawgomoo)
I understand that the closer you put a MBC to the wastegate, the less likely you are to spike. being closer to MBC the wastegate will get the boost signal more quickly when the MBC opens up, so the turbo will not keep spooling past whatever the target of the MBC is...
Old Aug 14, 2002 | 10:49 PM
cjmech's Avatar
Default Re: Grainger Valve for adjustable boost..know how to do it?? (ion_four)
<A HREF="http://www.xmission.com/~dempsey/perform/grainger.htm
" TARGET="_blank">http://www.xmission.com/~dempsey/perform/grainger.htm
</a>
This is what I was looking for if any one is intrested. My turbo has an internat wastegate, and with this setup I will be able to adjust boost very easily.
Cj
[Modified by cjmech, 7:50 AM 8/15/2002]
turbo_d
Jun 5, 2022 06:46 PM
98integralsB18
Jul 25, 2009 07:29 AM
Zach L
Mar 1, 2005 11:30 AM
gofastjdmcivic
Apr 28, 2004 04:29 AM
Elite Hatch
Oct 23, 2002 07:28 AM
