Precision 5431 or 5831??
Old Mar 16, 2013 | 08:22 PM
deuce_Fc's Avatar
Default Precision 5431 or 5831??
Which turbo?? Looking to only make 400hp on a b16a. Need a fast spooling turbo to make 400hp but not have the turbo work too hard. Both turbo are mfs. I got a couple of buddies running the 5431, one of them is making just a little over 400hp on a dyna pack dyno on 18-21 psi on a lsv. Any info or feed back with either turbos will help make me make my decision. Thanks.
Old Mar 17, 2013 | 04:17 AM
deuce_Fc's Avatar
Default Re: Precision 5431 or 5831??
Anything?
Old Mar 17, 2013 | 05:52 AM
nu2teg's Avatar
Um, Little hint man, Your a little vague in your question. Need some more info on your engine. Stock,Built,purpose? Leave out the psi referral!!!! There are several other questions that might be asked. This is all that I can do for you. Good luck on your endeavor!!!!!
Old Mar 17, 2013 | 08:54 AM
deuce_Fc's Avatar
81.5 forge pistons, b16a. Daily driver.
Wiseco 81.5
Eagle rods
Victor x mani
Gsr cams
Tial 44 gate
Tial 50 bov
Brms top mount, etc...
Both turbos are capable of producing the power goals I want at 400whp. Just want some Insight on which turbo will make that power easier with less boost. Atm I have a precision 4831. I'm looking to upgrade.
Old Mar 17, 2013 | 09:06 AM
utahturbosohc's Avatar
*edit* 5831. My brother and and friend both had their cars tuned this weekend with that turbo. Bros made 355@12 psi stock b16a. The other was a d16 vitara build, made 470@20ish I think it was. Great spooling street turbos.
Old Mar 17, 2013 | 09:07 AM
Charlie Moua's Avatar
isn't there a b16 turbo thread?
Old Mar 17, 2013 | 09:15 AM
TheShodan's Avatar
Moderator
Originally Posted by utahturbosohc
5431. My brother and and friend both had their cars tuned this weekend with that turbo. Bros made 355@12 psi stock b16a. The other was a d16 vitara build, made 470@20ish I think it was. Great spooling street turbos.
Could you please Verify those numbers? 355 by 12psi is something that's flowing over 60lbs/min at under 1.8pressure ratios. That turbo can't do that by design. a boost/rpm curve would be best. Until then... I'm horribly skeptical that occurred.
Old Mar 17, 2013 | 09:28 AM
deuce_Fc's Avatar
yes, there is a b16a turbo thread, but im looking for feedback on these two turbos.
Old Mar 17, 2013 | 09:29 AM
Eeerrrrr, my bad, 5831 is what I meant to type.
Old Mar 17, 2013 | 09:35 AM
deuce_Fc's Avatar
if im not mistaken both the 5431 and 5831 uses the same exhuast and compressor housing, what puzzels me is that why there's a power differences between the two, different compressor wheel design? the price difference of the two is 100 bucks. decisions decisions...
Old Mar 17, 2013 | 10:47 AM
the only experiance i've had with the 5431 is on a GSR turbo (goautoworks log manifold)... really ran out of steam after 400whp.
So we stopped there. I'm sure a better flowing manifold would help a little.
if your using on b16 for your 400whp goal just get the smaller 54mm 5431.
Old Mar 17, 2013 | 11:12 AM
deuce_Fc's Avatar
Those are some pretty good numbers, I'm leaning more towards the 5431 because of price, but as u stated the 5431 seems to run out of air, I'm just curious if the 5831 will make more power at the relatively same boost as the 5431.
Old Mar 17, 2013 | 12:38 PM
gotta understand cfm generated per psi will be different for each turbo, so generally Yes the 58 will make more topend power over the 54, but i doubt the 58 would have a broader powerband than 54.
Old Mar 17, 2013 | 12:59 PM
deuce_Fc's Avatar
True. Seeing that there both using the same housing will one generate boost quicker than the other?
Old Mar 17, 2013 | 06:34 PM
TheShodan's Avatar
Moderator
You sure? Still sounds out of its range.
Old Mar 18, 2013 | 09:29 AM
deuce_Fc's Avatar
Anymore feedback
Old Mar 18, 2013 | 06:23 PM
jdmsas's Avatar
5862 ftw!!!
Old Mar 18, 2013 | 10:58 PM
93typerhatch's Avatar
I made 355 on a piston and rod lsv on 13psi with the 5431.. Its for sale if u want it..
Old Mar 19, 2013 | 02:42 AM
mar778c's Avatar
Community Builder
Community Influencer
^^^pm'd
Old Mar 19, 2013 | 03:05 PM
deuce_Fc's Avatar
i might go with the 5831 as of now, im looking to push around 25psi at the track with a cnc werx block support or sleeved.
Old Mar 19, 2013 | 08:22 PM
GEN2 LS's Avatar
Loved
if this helps I had a 11:1+ CR b16 on e85 on a 6031 Precision with a .63 housing full boost around 5,000rpms and a 6031 is a larger turbo than either choices.
https://honda-tech.com/forums/forced-induction-16/e85-stock-block-ctr-pistons-boost-dyno-graph-3018979/
Old Mar 20, 2013 | 04:44 AM
deuce_Fc's Avatar
My comp is 8.8-9.1 so I figure it will spool the turbo a bit later with either of the two.
Old Mar 20, 2013 | 03:44 PM
TRIANGLE_BOY's Avatar
Stock b16a, cast manifold, pte5831, ID1000 injectors made 355 hp 245 ftlbs @ 12psi on 91 octane. My tuner said the 5431 would have been more efficient for my setup. No complaints here
Old Mar 21, 2013 | 03:33 AM
deuce_Fc's Avatar
Nice numbers, damn this is yet changing my mind again. if the garret 60-1 big wheel was cheaper, I would of got that one, put because of price these two turbos are giving me nuts.
Old Mar 21, 2013 | 04:49 AM
GEN2 LS's Avatar
Loved
Damn those are pretty good numbers for a b16, my old gsr stock bore with a mini-ram and 60-1 stage 3 wheel. 63 housing on 13psi made 355hp and 230ish torque on RLZ's dyno for reference. If I were you "deuce fc" i'd go with the 5831.
