Got my shotblock together *pic*
1 Post
Got my shortblock together *pic*
Well here she is..
Used JE 9.0:1 pistons ( took them to a machine shop, said they are mint )
Eagle rods
Type R crank
Golden eagle sleeves
Napa main bearings ( all spec'ed out to .0015 perfect!! )
OEM rod bearings
Everything is going well so far, just waiting for the arp headstuds! 450 + hp here i come!
-Josh
Modified by Blind Fashion at 11:53 PM 6/29/2004
Eagle rods
Type R crank
OEM rod bearings
-Josh
Re: Got my shotblock together *pic* (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">I give you 2 for building your own motor. I wish I had enough confidence to do that.</TD></TR></TABLE>
It's not hard at all....
Re: (Blind Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion »</TD></TR><TR><TD CLASS="quote">block is painted low gloss black.. engine enamal stuff..
Thanks for the comments guys!!</TD></TR></TABLE>
I like the looks of it ... Nothing fancy, nice clean look.
Re: (MustangPunk302)
god damn that looks like a big feed. also i am going to recomend a couple things to you.
1. dont tee of the back of the block like that, the vibrations can cause it to snap of INSIDE your block and it is a biatch to get out. use a fitler adapter, or run an aditional line straight from the block to the tee and mount it on your firewall.
2. ditch the pcv system, get a catch can setup on there. the fumes will kill your power, unless you have emmisions.
other than that looks good, i like the black block i wish i did that color instead of silver.
Landon
Landon
1 Post
the block fitting will not break, its steel and hugs the block.. lol, i even put one in my old d series blcok and tried to brake it off.. its ok...
anyways, how do i ditch the can? i mean there is a huge *** hole in the block.. if someone could help me out that would be great.
Re: (Blind Fashion)
i guarantee you it CAN break, ive done it and it sucks really really really bad.
do a search on catch can and pcv youll find a **** load of stuff. but i am running an endyne breather kit and it comes with all the stuf you need.
http://www.theoldone.com/components/breather/
you can do it for cheaper by getting the parts yourseld but i didnt feel like dealing with it.
Landon
Landon
Re: (redturbocivic)
Can you just let it vent into the atmosphere instead of spending that $$ on a catch can. I really don't have to worry about passing emissions, so will that work?
zex_cool
11-12-2008 05:43 PM
