Got my GE block today...one problem though.
Old Nov 3, 2003 | 10:38 AM
Kwuaymaikrup's Avatar
Default Got my GE block today...one problem though.
It isn't O-ringed. I am worried about blowing headgaskets. What kind of boost pressures are you guys running on non O-ringed blocks? I plan to run the Hondata max of 28 psi using a GE OEM overbored headgasket and AEBS head studs. Will I be OK? Any info is appreciated.
-Ryan
Old Nov 3, 2003 | 10:45 AM
DaveF's Avatar
Default Re: Got my GE block today...one problem though. (Kwuaymaikrup)
get it o ringed. thats my opinion.
Old Nov 3, 2003 | 10:51 AM
Bnjmn's Avatar
Default Re: Got my GE block today...one problem though. (2.2Lcivic)
I was under the impression that bore size dictated whether a block could be o-ringed or not? At least that is what GE told me. On the larger bores they said there wasn't enough space to o-ring.
In any case, your block has a stepped deck, no? That should help a bit too.
Old Nov 3, 2003 | 10:55 AM
Default Re: Got my GE block today...one problem though. (Bnjmn)
It is step-decked. As far as the bore goes it is 83mm. Anyone else?
-Ryan
Old Nov 3, 2003 | 10:56 AM
BodyKits NW's Avatar
You should be fine step decked.
Old Nov 3, 2003 | 11:16 AM
TurboTegB18c's Avatar
I'm running 21 psi non oringed, is working fine.
Old Nov 3, 2003 | 12:36 PM
boostaholic's Avatar
You don't need the tops to be O-ringed if it's step decked.
Old Nov 3, 2003 | 01:58 PM
boosted hybrid's Avatar
All GE blocks come standard with the step deck. Having GE O-ring the block is done at your choice as a no cost option. You'll be fine without the o-rings.
Old Nov 3, 2003 | 02:04 PM
TurboDANDEE's Avatar
Default Re: Got my GE block today...one problem though. (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">All GE blocks come standard with the step deck. </TD></TR></TABLE>
im new to that info... i thought step deck was optional?
Old Nov 3, 2003 | 02:16 PM
Kataku2K3's Avatar
Default Re: Got my GE block today...one problem though. (TurboDANDEE)
We only use OE (in some cases overbored) headgaskets... So far they've held just fine, detonation have taken a few out but that was our fault... We've gone up to 28lbs. on ~1.96L GE sleeved non O-ringed B18C's... Duc's B18C is O-ringed and runs 29lbs.... You should be fine, Peace
Old Nov 3, 2003 | 02:17 PM
They all come step decked. If you want it decked flat or with a O-ring it must be requested.
Old Nov 3, 2003 | 02:37 PM
alpha's Avatar
They all come step decked like everyone said. My block came back and it wasn't o-ringed. I sent GEM a copy of the order they sent me that said "I requested" the block to be o-ringed. They paid for shipping both ways. GEM
Old Nov 3, 2003 | 02:53 PM
AngelTeg's Avatar
time for my newbie question.... real quick, difference between stepdecking and normal decking?
anyone?
-Mike
Old Nov 3, 2003 | 02:54 PM
saso
Guest
Posts: n/a
Default Re: (0x64)
GE oringed my block so I use OE gasket.
Old Nov 3, 2003 | 02:57 PM
TeStUdO's Avatar
Default Re: Got my GE block today...one problem though. (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">We only use OE (in some cases overbored) headgaskets... So far they've held just fine, detonation have taken a few out but that was our fault... We've gone up to 28lbs. on ~1.96L GE sleeved non O-ringed B18C's... Duc's B18C is O-ringed and runs 29lbs.... You should be fine, Peace</TD></TR></TABLE>
A little OT but do you overbore your own stock headgaskets??
Old Nov 3, 2003 | 03:02 PM
trbob16a's Avatar
Default Re: Got my GE block today...one problem though. (TeStUdO)
you can run more boost on that non-oringed block than you will ever run...
Old Nov 3, 2003 | 03:06 PM
IloveNewt's Avatar
Did you ask them to O-Ring it and it "slipped" thier mind?
Old Nov 3, 2003 | 03:26 PM
Kataku2K3's Avatar
Default Re: Got my GE block today...one problem though. (MordecaiPSI)
Yea, normally you can just drill them out with a hole saw, j/k hehe... No if they're overbored they come from Golden Eagle...
Old Nov 3, 2003 | 03:28 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, normally you can just drill them out with a hole saw, j/k hehe... No if they're overbored they come from Golden Eagle...</TD></TR></TABLE>
Thats what I figured, just making sure
Old Nov 3, 2003 | 03:35 PM
GruvyTune's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">It isn't O-ringed. I am worried about blowing headgaskets. What kind of boost pressures are you guys running on non O-ringed blocks? I plan to run the Hondata max of 28 psi using a GE OEM overbored headgasket and AEBS head studs. Will I be OK? Any info is appreciated.
-Ryan</TD></TR></TABLE>
they had forgot mine too. i'm hoping its not a problem!~
Old Nov 3, 2003 | 07:58 PM
Default Re: Got my GE block today...one problem though. (GruvyTune)
Thanks for all the info guys. I can't remember if I wrote it on the work order or not. I think it will be fine though. Just wanted to get a general consensus first.
-Ryan
Old Nov 3, 2003 | 08:10 PM
BlueSi2k's Avatar
Default Re: (AngelTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AngelTeg &raquo;</TD></TR><TR><TD CLASS="quote">time for my newbie question.... real quick, difference between stepdecking and normal decking?
anyone?
-Mike</TD></TR></TABLE>
with normal decking the tops of the cylinders are even with the top surface of the block all around. When a block is step decked, the cyls come up a slight bit over the surface of the block. This is to aid in sealing...make sense?
MR.johnson
Jul 18, 2012 06:44 PM
TurboB16A300Hpteg
Feb 3, 2008 08:39 AM
turboZChatch
Oct 28, 2003 08:33 AM
SRL
Jul 10, 2003 08:47 AM
sleepercivic
Sep 11, 2002 08:12 AM
