good turbo or no?
Old Feb 19, 2002 | 06:07 PM
DOHCarp's Avatar
Default good turbo or no?
what do you guys think about this turbo for a B16A2. Also how hard will it be to modify the Drag gen 3 down pipe to fit that housing....hers the url
http://cgi.ebay.com/ebaymotors/aw-cg...tem=1805068550
Old Feb 19, 2002 | 06:10 PM
TurboSedan's Avatar
New User
Default Re: good turbo or no? (DOHCarp)
Well for one, the Drag DP has a 5 bolt flange so you'll have to cut that right off! Then you need to have a 4 bolt flange welded on.
Old Feb 19, 2002 | 06:13 PM
DOHCarp's Avatar
Default Re: good turbo or no? (97CivicFerio)
I wasn't sure if the Drag was a 5 bolt flange or not....I bought it but didn't get it yet. Thanks
Old Feb 19, 2002 | 06:17 PM
TurboSedan's Avatar
New User
Not a problem dude, anytime.
Old Feb 19, 2002 | 06:21 PM
DOHCarp's Avatar
What about the specs? will tehy be ok for a B16a
.48 Intake housing, .63 Exhaust Housing stage I
Old Feb 19, 2002 | 06:47 PM
dustin's Avatar
You'd be a lot happier if you got a t04e or t04b!
Old Feb 19, 2002 | 06:48 PM
DOHCarp's Avatar
Default Re: good turbo or no? (dustin)
what kind of diffrences will this turbo make compared to a T04e or T04b...thanks for the help guys.
Old Feb 19, 2002 | 06:52 PM
dustin's Avatar
Well, the t04x is just going to make more power. This little turbo will probably spool faster though.
You want the standard T3 outlet though, else you're going to have to custom build a downpipe ...
There is a reason that "brand new" turbo is currently at $250...
matt94z
May 26, 2009 10:04 PM
mbdelsol
Jun 17, 2005 04:34 PM
boost fed ls
Sep 30, 2003 02:21 PM
RyanAutry
May 7, 2003 04:50 PM
xero-cool
May 13, 2002 05:58 AM
