Golden Eagle VTEC Conversion Kit!
Old Jan 14, 2003 | 02:56 PM
  #51
LsTurbo91's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (DarksideDC4)
time to buy a new one eh?
Old Jan 14, 2003 | 08:20 PM
  #52
Rain_man's Avatar
New User
Default Re: Golden Eagle VTEC Conversion Kit! (LsTurbo91)
haha I'll just have to buy a few extra o rings for down the line. I don't doubt they are very nice o rings, but any o ring will go bad with time.
The reason I'm concerned, is because I plan on keeping my car til I die... yeah I'm a sentimental sap...
Old Jan 14, 2003 | 10:06 PM
  #53
LsTurbo91's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (GoldenEagleMfg.com)
can we get a groupbuy on this?
Old Jan 14, 2003 | 10:36 PM
  #54
LJR-LUDE01's Avatar
looks good... I might get me one to get oil to my turbo...
Old Jan 14, 2003 | 10:43 PM
  #55
V-SPEC 1's Avatar
Yeah Vince, group buy please.
Old Jan 15, 2003 | 07:48 AM
  #56
X-Mazda 3 Racer's Avatar
Let me ask you this, when a B16 has the oil conditioner on the back of the block, how does it seal to the block? A VITON O-RING! Do they ever go bad or have you heard of one leaking because the o-ring cracked or got old? I haven't, not once!!! These o-rings come with a lifetime warranty, no need to worry!
Old Jan 15, 2003 | 10:35 AM
  #57
nfn15037's Avatar
Yeah, and its not like they are gonna dry up from lack of lubrication
Old Jan 15, 2003 | 12:52 PM
  #58
stizzit's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (nfn15037)
You can nearly put together the entire LS/VTEC oil line kit for $89 and not go through much more trouble than you would screwing this onto the block and all the SS lines into it. I guess it depends on how big your wallet is. A reasonable price none-the-less.
Old Jan 15, 2003 | 02:34 PM
  #59
Hayasa15's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (stizzit)
Do you plan on making any of these for the d series blocks?
Old Jan 15, 2003 | 02:37 PM
  #60
Default Re: Golden Eagle VTEC Conversion Kit! (Hayasa15)
The units we have will fit all d-series, b-series ( without the B16 oil conditioner ), F-series and H-series.
Old Jan 15, 2003 | 03:04 PM
  #61
nfn15037's Avatar
What is a B16 oil conditioner? Are you talking about the oil/water heat exchanger? These will work on a GSR block, correct? i dontsee why it wouldnt...
Old Jan 15, 2003 | 05:12 PM
  #62
Rain_man's Avatar
New User
Good point, I didn't think of that.
Old Jan 19, 2003 | 12:15 PM
  #63
imonkie's Avatar
how much is this product?
Old Jan 19, 2003 | 11:00 PM
  #64
J2turbo21's Avatar
Which port is the turbo line and which is the vtec line?
[/QUOTE]
Old Jan 20, 2003 | 08:15 AM
  #65
Default Re: Golden Eagle VTEC Conversion Kit! (J2turbo21)
The Vtec uses the AN fitting, but we will also have a barbed fitting soon for people that don't want to spend that much on braided lines. The smaller 1/8" NPT is for turbo oil supply. Also, there are some other comapnies that make a product similar to theis, but their product lets you tap into UNFILTERED oil!!! DOn't use these cheap knock-offs. They can damage your turbo or rocker assembly if used for VTEC oil supply! Our VTEC Conversion kit uses FILTERED oil, essential for long lasting performance!
Old Jan 20, 2003 | 08:49 AM
  #66
earl's Avatar
You might think I have something against your company but I really don't. You make good products. BS claims, however, just drive me crazy.
This means that the B18C was designed wrong by Honda because it sends unfiltered oil to the valve train? Do B18C valve trains wear out in 50K miles? I don't think so. This product looks great. Perfect for VTEC conversions and other uses. Don't taint it with BS. You don't have to use scare tactics to sell your products. The similar products are NOT going to damage turbos or rocker arms.
Old Jan 20, 2003 | 08:54 AM
  #67
Default Re: Golden Eagle VTEC Conversion Kit! (earl)
First of all, wrong board Earl! Second thing is I am talking about the AC Autotechnic Oil Distribution block. YOU CAN ONLY RECIEVE UNFILTERED OIL FROM THIS PRODUCT WHICH CAN DAMAGE TURBOS AND ROCKER ASSEMBLIES!!!
The B18C uses filtered oil for the VTEC and rocker assemblies. It gets the oil AFTER the filter! ALl I am saying is that other products can damage a good turbo with particles in the oil. If you took a second and read what I said, then you would realize what I was talking about!!! Damn.....
[Modified by GoldenEagleMfg.com, 6:04 PM 1/20/2003]
Old Jan 20, 2003 | 09:05 AM
  #68
TurboTegB18c's Avatar
I have the factory oil cooler on my block and want to run the turbo feed and oil pressure sender off this oil block. Will this work? Please let me know. Paul
Old Jan 20, 2003 | 09:07 AM
  #69
Default Re: Golden Eagle VTEC Conversion Kit! (TurboD16Z6)
We will have a unit available for use with the factory oil cooler very soon. please give us a call (909) 592 - 4311
Old Jan 20, 2003 | 09:49 AM
  #70
earl's Avatar
All oil is filtered inside of the block at some time. How can the AC block (which I am not familiar with) get unfiltered oil? If it draws from the main oil gallery, it's getting the same oil as the bearings are getting. It can't be bad. This same gallery feeds the rockers in the vtec motor. Any time I reply, I read the post several times to make sure I don't look like an idiot. I understand what you are saying, I just don't agree with it.
Old Jan 20, 2003 | 09:53 AM
  #71
Their product pulls oil from BEFORE the filter. This is why we call this UNFILTERED oil! Our unit pulls oil from AFTER the filter, hence this would be called FILTERED oil! Maybe I should draw you something so you can understand?
Old Jan 20, 2003 | 10:09 AM
  #72
earl's Avatar
I do understand. I would think you would understand more about the oil flow in a Honda. It is not a system that funnels all the oil thru the filter before returning it to the pan. It only pulls random oil and filters it. (It actually feeds off of #3 main.)Pulling oil from the main gallery that supplys the bearings and rockers is not bad. It gets filtered also. You have a GREAT product but let's agree to disagree on the reason why it is great I'm done
Old Jan 20, 2003 | 10:18 AM
  #73
O.K. now I know that you know nothing about the B-series oiling system. Your done, I'm not! A B-series motor DOES filter ALL the oil, what are you thinking!!!???
Oil pickup goes into the oil pump ( only one inlet port ), then it feeds the oil into the block ( oil pump only has one feed hole into the block ) this hole then goes directly to the filter!!! I agree that you may not like why I made this products, but you CANNOT misinform people about their motors. ALL THE OIL GETS FILTERED! LOOK FOR YOURSELF EVERYONE!!! Can someone set this guy straight, he doesn't listen to me!!!
Old Jan 20, 2003 | 10:22 AM
  #74
integra-modder's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (hondaswaper)
most people use a -6 line to feed the head, as the stock VTEC feed hole is 3/8th's
is there away to make yours a -6 ??
Yes, that is what that other port is for. Either turbo oil feed or pressure sending unit sensor. It is a 1/4" NPT ( pipe thread ) and the Vtec port is a -6AN.
Old Jan 20, 2003 | 10:37 AM
  #75
Default Re: Golden Eagle VTEC Conversion Kit! (integra-modder)
I second that comment about having a group buy.
Since you get many of your ideas and input from HT, you should offer an HT special group buy at a lowered price.
