golden eagle sleeve question...
Old Apr 16, 2002 | 08:42 AM
  #26
clendaniel's Avatar
Default Re: golden eagle sleeve question... (Anubyss)
Heh...that's my GE-sleeved h22. Keep in mind that the motor is not bored/honed in that pic, it's as I received it back from GE. I lost a little thickness but not much (I stayed w/ 87mm), I'll try to dig up a pic of the finished motor.
--Ian
Old Apr 16, 2002 | 08:55 AM
  #27
2000Accord5sp's Avatar
Default Re: golden eagle sleeve question... (clendaniel)
So do you guys think it's the safest to keep the stock bore if going high boost? Just because of problems I've heard and I like being extra safe, I'm keeping my stock bore and planning on boosting about 18-20psi. h22 open decks are already scary enough to go boost so I figured I'd have GE put in new sleeves with stock bore. Am I just stupid???
Old Apr 16, 2002 | 09:09 AM
  #28
Smurfylude's Avatar
Default Re: golden eagle sleeve question... (gsr*lude)
Hey gsr*lude,
I was think about going 90mm bore on a H22 sleved by GEand then turbo charging. Do you think the block will be able handle 15 - 20PSI of boost? Or should I stay with 87mm or 89mm? Just wanted some input. Thanks
Old Apr 16, 2002 | 09:22 AM
  #29
Liltrix's Avatar
Default Re: (Anubyss)
Hey Anubyss
Wanna sell me Ur block?
Old Apr 16, 2002 | 09:32 AM
  #30
2K_TEG's Avatar
Default Re: golden eagle sleeve question... (dustin)
65psi static? Heh, my compression tester shows 230psi static on stock sleeves
Maybe they're just trying to convince you that the sleeve-holding cement won't leak?
I can't imagine that they are touting that number as the amount of boost you can run, everyone must be confused.
Dustin
They pressurize the coolant system to 65psi. I normally runs at 16 or 30, I can't remeber. It is to check for coolant leaks and make sure eveything is installed properly, it has nothing to do with boost.
Old Apr 16, 2002 | 09:38 AM
  #31
Anubyss's Avatar
Default Re: (Liltrix)
Umm I am not selling my block. I am looking for one. If I find one and get my turbo done, then maybe I can sell mine. That won't be for a while though.
Old Apr 16, 2002 | 09:39 AM
  #32
Liltrix's Avatar
ok cool
Old Apr 16, 2002 | 09:41 AM
  #33
Default Re: golden eagle sleeve question... (2000Accord5sp)
anyone? sorry...just want assurance maybe that I didn't waste money on getting GE sleeves with stock bore. :S
Old Apr 16, 2002 | 09:52 AM
  #34
Anubyss's Avatar
I think you should stay stock bore. If you mess something up, that gives you the chance to rebore to 89mm or 90mm. It's better than having to resleeve. This was recently brougt to my attention.
Old Apr 16, 2002 | 10:23 AM
  #35
The Punisher's Avatar
To each his/her own. I am not looking to blow my motor and I will be running 25+ psi of boost on my 90 mm bore. I am using Endyn pistons and rods. I will be using Hondata as my fuel management. Go with what makes you comfortable. If you want the stock bore, stay with it. If you want to go ***** to the wall, get the 90 mm. I will post pics. I used a H22A1, Golden Eagle kept my block a closed deck!
[Modified by gsr*lude, 4:51 PM 4/16/2002]
Old Apr 16, 2002 | 10:30 AM
  #36
Yea, I hear you guys...I have the h22a4, golden eagle sleeves with stock bore, JE 9:1 pistons, and crower rods. I'll take it one step at a time with boost but I'm pretty confident that at 20psi I shouldn't have any problems.
Old Apr 16, 2002 | 11:04 AM
  #37
JASON77's Avatar
This all sounds very cool to me.....but I have one question assuming that you get your 1.6/1.8/2.2 what ever, bored out. This will no longer be street legal? Pass smog? Dam california laws if so.
Old Apr 16, 2002 | 11:20 AM
  #38
Anubyss's Avatar
I spoke with a tech at GE and he said I shouldn't go with 90mm if I want to boost. Just repeating what he said. I don't really have first hand experience. So I bought the 87mm JE pistons with eagle rods.
Turbo won't pass emissions anyway unless you go with Greddy. You'll have find a 'friend' to pass you for state inspections.
Old Apr 16, 2002 | 12:55 PM
  #39
X-Mazda 3 Racer's Avatar
Default Re: golden eagle sleeve question... (2K_TEG)
Here is the end all be all. My name is Vince Tiaga from Golden Eagle Mfg. and yes, we pressure test the coolant area for leaks at 65 psi. to make sure there is no water leaks into the oil chamber ( tested at 165 F ) . I also " RATE " my blocks at 60 LBS of turbo boost ( on a running motor with fuel and everything, not static!!!! ) I always tell people, you will blow the head off the block, before you crack a sleeve from us ( Golden Eagle Mfg. ) even up to 85 mm on a B-series. I can say this because we have taken cars to this limit before and they have held up perfectly with no distortion and no headgasket failure ( if using a copper wire o-ring and a stock 3-ply steel headgasket bored to the correct size for the motor, installed with copper spray, ARP headstuds torqued to 78 ft. lbs. and no detonation. ) This may seem like alot of mumbo jumbo, but it is the truth. If anyone cracks a sleeve of ours due to boost pressure ( not including detonation, valve drop or any other mechanical or tuning failure ) and our techs agree that only boost pressure is the culprit for the crack, we will replace the sleeves free of charge and pay for shipping of the block next day to wherever you are. I told one of my customers this weekend at Texas IDRC that if he wanted to beat the car he was up against, he should just turn up the boost!!! 47 lbs. of boost all the way down the track and not one problem with the motor. As long as you have the right internals, tuning and experience, don't be afraid of the boost levels rising past 30 lbs. especially if you are running one of my blocks. Remember this also, the bottom end does not " make " horsepower, it just holds it! Any questions or concerns can be sent to me directly at vince@goldeneaglemfg.com
Thanks for your time.
Old Apr 16, 2002 | 01:00 PM
  #40
voltronR34's Avatar
Default Re: golden eagle sleeve question... (V8KILR)
Thats great! Thanks for posting here!
Old Apr 16, 2002 | 01:04 PM
  #41
tonydatyga's Avatar
nice... GB md/dc/va this summer?? actually location doesn't matter so anybody looking to sleeve late this summer around july...
Old Apr 16, 2002 | 01:31 PM
  #42
TurboDANDEE's Avatar
Default Re: golden eagle sleeve question... (tonydatyga)
i was there when Vince told a local shop here in Houston (Hyper Racing) to boost it up to 45psi. Vince said, if he breaks the block, he will replace it, the car ran fine with no problems. Golden Eagle is a good proven product that we will all be running.
Old Apr 16, 2002 | 02:29 PM
  #43
turbo Si's Avatar
Default Re: golden eagle sleeve question... (JiSATSU RaceR)
Man you never meet Vince. You don't even know what your talking about, so stop posting you and your slow *** car! I saw you fools up in San Antonio. Ya'll were slow. When I get my car running I'm gonna show yall up. Especially that silver civic, and green hatchback with those clean *** bogarts!
[Modified by turbodaddy, 11:31 PM 4/16/2002]
Old Apr 16, 2002 | 02:50 PM
  #44
turbo Si's Avatar
O'h and that guy who is selling off all his parts, what's his name, p-dang. He's selling off all that because he saw me coming. Don't be scared! Ya'll lucky ya'll got Jimmy though, i'll give ya'll that!
Old Apr 16, 2002 | 04:03 PM
  #45
Default Re: golden eagle sleeve question... (turbodaddy)
OK HATER, drugs are bad! did i say that i met Vince? No. Hyper was telling us what he said at the race, get your **** straight, moron. If u dislike us so much, why dont you come to the shop and fill out a complaint form and we'll try to solve your problem the best way we can. And if your car is so fast, im pretty sure we can arrange some kind of a race between your car and ours. and one more thing, quit stalking us, you PSYCHO!
Old Apr 16, 2002 | 04:46 PM
  #46
turbo Si's Avatar
Man I'm just ******* with ya'll. This is David! I was at school, board as hell, and I ran across your post. So I changed my screen name to turbodaddy. Man I thought the **** I said about the wheels would of gave it away! Anyway's it was fun.
See ya!
Old Apr 16, 2002 | 04:48 PM
  #47
turbo Si's Avatar
Default Re: golden eagle sleeve question... (dsmturbosi)
So don't anyone take what I said seriously.
Sighned,
dsmturbosi <aka : turbodaddy>
Man that was funny!!!!!
[Modified by dsmturbosi, 1:49 AM 4/17/2002]
Old Apr 16, 2002 | 05:02 PM
  #48
FOCKER!
Old Apr 16, 2002 | 06:33 PM
  #49
Ltech's Avatar
anywayz, It wasn't funny.
Old Apr 16, 2002 | 07:04 PM
  #50
turbo Si's Avatar
Default Re: golden eagle sleeve question... (Ltech)
Sorry, but it was more of an inside thing. Not that it was meant to amuse anybody!
datbumper
Apr 30, 2013 04:54 PM
12secdc2
Dec 4, 2008 09:25 PM
Death_to_Thieves
Nov 25, 2004 07:51 PM
dunkd
Aug 31, 2004 09:00 AM
VNTEC
Dec 22, 2003 12:46 PM
