Going FI.. preperations?
Old Oct 6, 2001 | 12:47 PM
Cow's Avatar
Cow
Default Going FI.. preperations?
I've decided I'm probably going to go turbo/SC with my stock 94 GSR, and I was wondering what kind of stuff I'd want to get to compliment it. I think I saw somewhere that certain NA stuff won't work well with FI, like cams and whatnot. Can someone help clarify this and give me a basic rundown of what I'm looking at, both parts and money wise?
Old Oct 6, 2001 | 12:56 PM
chri5's Avatar
Default Re: Going FI.. preperations? (Cow)
it depends if you are going to go turbo or SC....That is the first choice you need to make.
Old Oct 6, 2001 | 01:19 PM
Cow's Avatar
Cow
Default Re: Going FI.. preperations? (Chris_Turbo)
I'm probably going to go turbo. What would I need for that?
Old Oct 6, 2001 | 07:34 PM
Etylorcen's Avatar
Well if you get some cams with high lift and long duration then go FI the compressed air is just going to blow by through the chambers and not really help too much. Usually stock cams or specific turbo cams are the best bet. As with all motor you want high compression which is a no no for FI. YOu want to lower your CR so you have less chances of detonation. For now you could always get some forged rods which wont hurt and will definately help when you go FI. As for the exhaust get a 3'' but not until you're boost or you'll lose tons of power.
Old Oct 6, 2001 | 10:44 PM
DIRep972's Avatar
Smarter than you
A very good exhaust system will help out more then anything.. And also a very good clutch..
If u go SC, TypeR cams are not a bad, Since the Roots Supercharger works off of the power of your motor, my friend had a JRSC GSR w/ typeR cams, he made 230whp then we told him to put in the GSR cams in, he lost power.. ..when u have the cams properly timed you wont experience a loss of boost.. this is not true with allmotor cams, They are just WAY to high lift.. but typeR cams actually work good
Old Oct 7, 2001 | 08:42 AM
Cow's Avatar
Cow
Default Re: Going FI.. preperations? (DIRep972)
Maybe I should be more specific.. I'm looking to hit about 320 hp at the wheels with a turbo (don't know which one would be best yet). I know I'll need new pistons, rods, injectors and fuel pump. Is there anything else I'm forgetting?
Also, DIRep, what clutch would you recommend?
Thanks..
Old Oct 7, 2001 | 11:22 AM
954DR's Avatar
New User
Engine management.
Haltech/Hondata/TEC11 etc.
$0.02
[Modified by 954DR, 8:22 PM 10/7/2001]
Old Oct 7, 2001 | 11:27 AM
DR. ON POINT's Avatar
Banned
ahh yee of little faith...stock rods are just fine
Old Oct 7, 2001 | 01:52 PM
Cow's Avatar
Cow
Default Re: Going FI.. preperations? (On Point)
Really? Everything I've seen says you'll need new rods if you plan to go above like 9 psi or so..
Old Oct 7, 2001 | 02:52 PM
TurboSedan's Avatar
New User
The only thing that will cause the rods to pop is if the tuning is harsh enough to allow detonation. If there is detonation then the stock rods will be much more likely to break. I have yet to see proof that when stock rods break it is just because of too much boost/hp. In every case I have seen/read/heard it has been bad tuning and detonation that resulted from that which caused the breakage.
Old Oct 7, 2001 | 04:08 PM
DIRep972's Avatar
Smarter than you
ACT, clutchnet, and clutchmasters are all good.. Im not an expert on clutches but just make sure u get a clutch that can handle the power, is streetable, and u are comfortable with the engagement..
playalistic2
Jun 23, 2005 10:41 AM
punzak
Jul 18, 2002 12:23 PM
Dorikamu
Jun 13, 2002 06:05 PM
Acura_I-RS
Mar 6, 2002 01:56 PM
617arg
Jul 17, 2001 05:56 AM
