goign from t25 to 14b what needs changed
Old Aug 22, 2006 | 07:44 PM
blackccoupe's Avatar
Default goign from t25 to 14b what needs changed
i'm goig from a t25 to a 14b i am using the hf mani adapter setup, what all besides the intercooler piping needs changed, any input is appreciated
Old Aug 22, 2006 | 08:06 PM
Bailhatch's Avatar
Default Re: goign from t25 to 14b what needs changed (blackccoupe)
garrett and mitsu oil feed and drain fitting are different. Not sure on the water fittings, if you are runing that.
and you must already know about the compressor outlet facing a different direction entirely. might be a problem if you want to run the internal gate.
Old Aug 23, 2006 | 03:46 PM
Default Re: goign from t25 to 14b what needs changed (Bailhatch)
sorry its a dsm t25
Old Aug 23, 2006 | 06:38 PM
Bailhatch's Avatar
right. garrett makes the t25 and mitsubishi makes the 14b
Old Aug 24, 2006 | 11:55 AM
anyone else do this switch it s a 96 2nd gen t25 i wanna switch that to a 14b
Old Aug 24, 2006 | 12:28 PM
TTT's Avatar
TTT
water lines will bolt up. Will need to change the oil inlet fitting and oil outlet drain flange. Also the compressor outlet is different (which you already know of)
AJxr
Sep 14, 2009 01:52 PM
N20civicB18
Dec 19, 2006 01:07 PM
W O T
Feb 15, 2005 02:50 PM
Poop111444
Jul 8, 2003 06:08 AM
technine
Jun 14, 2002 07:30 PM
