Nice T3 turbo - needs rebuild - oil feed line and drain line included
Ok. I have a T3 turbo that to the best of my knowledge, came off a Nissan SR20DET. The exhaust side is .48, and i believe the compressor is a 50 or 57 trim wheel, but im not sure. It has a 2.25" inlet. The turbo was on my 99 Si with a stock b16a2. It needs a rebuild - it has shaft play. It was working fine, but a piston pooped out on me, so when i took off the manifold i saw it had some shaft play. Does not burn or leak oil, as my charge pipes were clean of oil.
This turbo is oil and water cooled. The fittings for water cooled are included, but the oil drain flange and oil inlet flange are NOT included.
As a bonus, im throwing in 3.8 ft of -3AN line with EARLS fittings. One end was slightly leaking, but I will use my new vice and reinstall the hose end again and it should be ok. I am also included some -10AN drain line as well.
The oil feed flange and oil drain flange is NOT included - but the lines are. The 2" outlet silicone and 2 T Bolt clamps ARE INCLUDED
I accept PAYPAL and i am verified. I will also take a MO. I have plenty of positive ebay feedback. If your interested - email me knurmi00@yahoo.com
This turbo almost got me into the 13s with a stock motor 99 Si, full interior and AC at 8.5psi. As you can see, my slips show this. I had to shut down on the first two runs because a spark plug pooped out on me and fuel cut off at 7K RPMs.
I was thinking $85 shipped for this.
Thanks
Thanks
Scott - 93HB Si
09-04-2002 04:14 AM
