GN turbo
Old Aug 18, 2004 | 08:59 AM
vbphreak's Avatar
Default GN turbo
does anyone have specs on this factory turbo?
I can't find any information on it other than rebuilding kits.
BUICK Grand National/T-Type 86-87 3.8L (Intercooled) GAR TB0348 (TA48)
This will be mated to a D16Y8 if this info helps. TIA
Old Aug 18, 2004 | 09:09 AM
Tchleung's Avatar
Default Re: GN turbo (vbphreak)
I asked the same questions.
https://honda-tech.com/zerothread?id=935681
Old Aug 18, 2004 | 09:21 AM
vbphreak's Avatar
Default Re: GN turbo (Tchleung)
thanks for the link.
what modifications had to be done to fit it to a standard T3 flange?
Old Aug 18, 2004 | 09:35 AM
Tchleung's Avatar
I hacked off the 3 bolt ford flange, and welded a T3 flange onto it.. etiehr way. you'll ahve to weld somethnig tog et it fit or make an adapter plate.
Old Aug 18, 2004 | 08:09 PM
RMF
Guest
Posts: n/a
I build turbo kits for hondas and have a GN [87] and if you have the stock turbo
it will work perfect on a 1800 to 2000 cc motor . it will come on about 55 or 6
and make plenty of boost as far as the 3 bolt flange you,ll have to change your
manifold flange
aryiman98civic
Welding / Fabrication
Oct 2, 2006 08:46 PM
bambbrose
Apr 10, 2006 07:41 PM
gdrum
Sep 8, 2004 09:55 AM
94lsboost
Dec 18, 2003 10:37 AM
