GN turbo
does anyone have specs on this factory turbo?
I can't find any information on it other than rebuilding kits. BUICK Grand National/T-Type 86-87 3.8L (Intercooled) GAR TB0348 (TA48) This will be mated to a D16Y8 if this info helps. TIA |
Re: GN turbo (vbphreak)
Re: GN turbo (Tchleung)
thanks for the link. https://honda-tech.com/forums/images...es/emsmile.gif
what modifications had to be done to fit it to a standard T3 flange? |
I hacked off the 3 bolt ford flange, and welded a T3 flange onto it.. etiehr way. you'll ahve to weld somethnig tog et it fit or make an adapter plate.
I build turbo kits for hondas and have a GN [87] and if you have the stock turbo
it will work perfect on a 1800 to 2000 cc motor . it will come on about 55 or 6 and make plenty of boost as far as the 3 bolt flange you,ll have to change your manifold flange |
