What turbo manifold, or flange for K26 turbo?
I have a K26 that came w/a lovefab manifold (in a trade) and i sold the lovefab and don't have the turbo here right now, so does anyone know?? I want to buy a manifold that will bold right up w/out having to reweld a flange
Re: What turbo manifold, or flange for K26 turbo? (94lsboost)
What is the bolt pattern on the turbo? If its the same as a standard t3 or t4 then a LoveFab would fit both as Cody double drills his flanges. Either pattern, all you need is a manifold with the respective flange on it. If the bolt pattern is completely custom then youre going to have to cut and weld a flange regardless of manifolds.
I dont know anything about that turbo but this is general info.
Re: What turbo manifold, or flange for K26 turbo? (phiberoptik)
KKK turbos have a 4 bolt pattern a little smaller than a t3 but rather than having a rectangle opening it is a round opening that is wider than the bolt pattern. I have some kkk flanges being made at this time. Let me know if you are in need of one down the road.
Re: What turbo manifold, or flange for K26 turbo? (RenoRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">KKK turbos have a 4 bolt pattern a little smaller than a t3 but rather than having a rectangle opening it is a round opening that is wider than the bolt pattern. I have some kkk flanges being made at this time. Let me know if you are in need of one down the road. </TD></TR></TABLE>
how much $$?
how much $$?
