Gm 3 bar map sensor scaler and offset??
Old Apr 11, 2006 | 10:10 AM
flip1199's Avatar
Default Gm 3 bar map sensor scaler and offset??
Does anyone know the scaler and offset of the gm 3 bar map sensor?
Old Apr 11, 2006 | 11:16 AM
tgreaves's Avatar
Default Re: Gm 3 bar map sensor scaler and offset?? (flip1199)
What one?
Old Apr 11, 2006 | 04:38 PM
flip1199's Avatar
Default Re: Gm 3 bar map sensor scaler and offset?? (tgreaves)
does anyone have the scaler/offsets for any of them?
Old Apr 11, 2006 | 07:03 PM
nowtype's Avatar
http://forum.pgmfi.org/viewtop...sheet
I'm a nice guy.
Old Apr 11, 2006 | 10:07 PM
flip1199's Avatar
Default Re: Gm 3 bar map sensor scaler and offset?? (nowtype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">http://forum.pgmfi.org/viewtop...sheet
I'm a nice guy.</TD></TR></TABLE>
well i glanced through that thread and it was mainly talkin about the aem 3.5bar sensor with a diagram of the gm 3bar at the end. but in the diagram it didnt give the scaler/offset. is there a formula to get the scaler/offset from the info given in that diagram?
Old Apr 11, 2006 | 10:31 PM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">
well i glanced through that thread and it was mainly talkin about the aem 3.5bar sensor with a diagram of the gm 3bar at the end. but in the diagram it didnt give the scaler/offset. is there a formula to get the scaler/offset from the info given in that diagram?</TD></TR></TABLE>
I think it's posted in the hondata forum. I know I've seen it there...
Old Apr 12, 2006 | 05:51 AM
tgreaves's Avatar
Default Re: Gm 3 bar map sensor scaler and offset?? (TurboChrgd_Civic)
If you look in the AEM software you can select the sensor and then check the settings for it..
Old Apr 12, 2006 | 08:22 AM
nowtype's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">well i glanced through that thread and it was mainly talkin about the aem 3.5bar sensor with a diagram of the gm 3bar at the end. but in the diagram it didnt give the scaler/offset. is there a formula to get the scaler/offset from the info given in that diagram?</TD></TR></TABLE>
Um, break out your Algebra I book and do the math.
y = scalar * x + offset.
Y is either voltage or pressure, X will be the other variable. Swap around the formula. Do some simplification, and come up with a solution. I know its 9th grade all over again, but you're going to have to tough it out like you dud then.
RACEPAK
Jan 30, 2008 10:44 AM
Kid_SiR
Dec 28, 2007 03:07 AM
Greg H
Sep 23, 2006 06:58 AM
cigrafix
Sep 19, 2006 04:26 PM
Topdawgg
Jan 18, 2006 05:15 PM
