Turbo Question
Old Apr 12, 2006 | 07:45 AM
TrunkRattlin's Avatar
Default Turbo Question
Im buying a turbo pretty soon, and getting a used one, but i want to make sure the turbo isnt missing anything, so could you guys help me out and tell me what parts the turbo itslef has to have so i dont have to buy anything else for just the turbo (ex. exhasut housing...and i dont know what else)
Old Apr 12, 2006 | 07:57 AM
dohcdelsol93's Avatar
Default Re: Turbo Question (TrunkRattlin)
exhaust/compressor housing and fins, that's about it. The main thing is checking for shaft play and make sure there are no fins missing. A ball bearing turbo will have no up/down or side/side shaft play and a thrust bearing turbo will have a small bit of up/down play (just a few thousands just to where it is noticable) and no side/side play. Then you just hope that the seals are not gone, the seals cannot be inspected unless removed.
Default Re: Turbo Question (dohcdelsol93)
ok, so look for the exhaust housing, and what are the fins?
Old Apr 12, 2006 | 08:00 AM
Soccerking3000's Avatar
the actual turbines...
if either housing is missing you will know it trust me. go to phonenixturbo.com and click on the pics of the turbos to get the general idea. The fins are on the inside of the compressors. They are basicly fan blades. If the bearings are shot or the turbo has sucked something in they will usually be damaged, missing, chipped or bent.
Oh, and check the exhaust side for any oil residue. That will give you a little indication if the oil seals are leaking or not but it is not 100%
Old Apr 12, 2006 | 08:01 AM
o ok, and what about nipples (soneone told me) he said they were missing or something?
Old Apr 12, 2006 | 08:07 AM
nippels? I guess they are talking about the oil feed and return fittings. You can order the return flange from fastturbo.com or ebay for 5-15 bucks and get the fittings for the feed one and return flange to return line for a few bucks at a local hose/hydro shop. Make sure you do your research before hooking this up, you don't sound too familiar with a turbo set up and this can end up costing you alot of unneeded headache and thrown away money if not approached correctly.
Old Apr 12, 2006 | 08:18 AM
yeah im not too familiar but i have done the basic research, so ill just hope to get it with all of it attached
Old Apr 12, 2006 | 08:25 AM
even if you do, unless it's out of a honda it probably won't fit. feel free to pm me with any questions and don't forget to research the turbo you get. With most turbos you will need to reduce the pressure for the turbo feed line. Other than that -3an feed line and -10an return line is all you need along with a few fittings
Old Apr 12, 2006 | 08:29 AM
thanks i appreciate all of your help...m building a custom kit for my d16
hbyrd8701
Jan 19, 2008 07:43 AM
hifonics
12
Jun 4, 2007 05:24 AM
integracivic94
Oct 5, 2005 11:38 AM
lke2drvgsr
Aug 17, 2005 08:25 PM
POWERINTEGRA
Nov 28, 2004 07:25 PM
