Girdle, caps, line bore...recomendations
Old Aug 4, 2007 | 12:49 PM
80884's Avatar
Default Girdle, caps, line bore...recomendations
So I dropped off the block at the machine shop today. Also the crank to be fixed and balanced. Refer to this for pics of why it's going to the machine shop https://honda-tech.com/zero...age=4.
Im open to a few options and wanted to see what would be the best way to go about it.
1. oem girdle
2. aftermarket 3 point girdle
3. 5 point girdle
4. have girdle made at machine shop
I really like the idea of the 5 point girdle but the price is kind of out there.
The engine is there for line bore, having main studs installed and getting bored. I figured now is the time to add a girdle since I'm having the line bore done also. Is the oem girdle a worthy upgrade?
Thoughts...
Old Aug 4, 2007 | 01:21 PM
tony1's Avatar
Default Re: Girdle, caps, line bore...recomendations (80884)
I'd throw that crank in a dumpster before i paid to have it repaired. Turned honda cranks almost always lead to problems. Find a good stock crank and use it.
On the line bore, make sure the machine shop understands that the crank centerline CAN NOT be moved or you will have oil pump problems..
Old Aug 4, 2007 | 05:07 PM
80884's Avatar
Default Re: Girdle, caps, line bore...recomendations (tony1)
Ok, I'll get the crank from him that I sold to him a long time ago. He also has a stock stroke eagle crank but I see no need for that. Wasn't aware that after turning they became a problem.
I explained to him about the crank centerline needing to stay where it is. His response was it should stay where it is at unless the line bore is off enough right now that it would require more than .002" removed from the block side of the mains, and if that was the case he said he would recommend scraping the block.
He asked how much power I was looking to make. I told him probably 700whp or more. He looked at me and smiled kind of weird and said that since I was getting it line bored I could even go with Billet main caps, He must think I have lots of money to spend. I told him to check on how much they are and let me know.
I just think it would be a good idea to add a girdle at this point, needed? maybe no but is it going to hurt? no.
Thoughts on balancing a stock uncut honda crank?
Old Aug 4, 2007 | 05:46 PM
NJIN BUILDR's Avatar
I have balanced Honda cranks on a few different balancers and they are real close from the factory.Personally I would not pay anyone the balance one for me.I would find another shop with experience with Honda blocks/caps.They are a bitch to do correctly.I would not use a reground Honda crank or an Eagle crank.I'm also not all that hot on girdles.Done correctly they will not hurt anything but most of the loads on the caps are vertically and I don't see a girdle helping that any.
Old Aug 4, 2007 | 07:25 PM
tony1's Avatar
Default Re: Girdle, caps, line bore...recomendations (NJIN BUILDR)
Billet mains, huh? I'd find a machine shop with some honda experience...
Old Aug 4, 2007 | 10:08 PM
Jared's Avatar
sounds like the machine shop is iffy at best. you are in the ne, send your stuff to jj and be done with it.
Old Aug 5, 2007 | 12:35 AM
rmcdaniels's Avatar
Default Re: (Jared)
Get a different machine shop.
Old Aug 5, 2007 | 05:29 AM
BoostedJeff's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the machine shop is iffy at best. you are in the ne, send your stuff to jj and be done with it.</TD></TR></TABLE>
yep.
Old Aug 5, 2007 | 06:12 AM
DaveF's Avatar
Default Re: (BoostedJeff)
im sorry but there are more than one machine shop more than capable of machining the block. expletive the hype
Old Aug 5, 2007 | 06:14 AM
tony1's Avatar
Default Re: (dturbocivic)
Of course there is, but it's nice to deal with someone with some honda experience, and if this guy is recommending billet main caps for 700hp, he obviously has no honda experience. As sensitive as these blocks are to any crank/main work, if it's not 100% it's going to lead to a lot of oil pump problems.
Old Aug 5, 2007 | 07:05 AM
80884's Avatar
Default Re: (tony1)
Just to shut some people up, this guy knows what he is doing. He doesn't do honda only engines like some shops do, so he just said about putting them in. He didn't say you should do this or you should do that.
I'm not giving him the engine and telling him I want this much power do what ever you think it needs and let me know. He is doing what I tell him to. He does alot of different things for different types of racing and actually does a good bit of work for other shops that can't actually build engines.
The fastest 4cyl engine that he has built is in a ford probe, rwd, 7.60's 1/4.
Either way, I trust his work 100% I just need to know what I should have done and if adding the girdle will be worth it.
Old Aug 5, 2007 | 04:40 PM
DaveF's Avatar
Default Re: (80884)
do an aftermarket 3 main and be done with it. put main studs in it too.
Old Aug 5, 2007 | 07:13 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I'd throw that crank in a dumpster before i paid to have it repaired. Turned honda cranks almost always lead to problems. Find a good stock crank and use it.
^^^ truth!
yea your crank looks absolutely horrible. find a new one.
exospeed went through alot of cranks before they finally found a good one for my engine. very important.
Old Aug 6, 2007 | 05:28 AM
80884's Avatar
Thanks Dave, thats the response i wanted.
New crank, aftermarket girdle, line bore, cylinder bore/hone, other new parts, try again.
Any recomendations on an aftermarket girdle to get or stay away from?
Old Aug 6, 2007 | 06:46 AM
DaveF's Avatar
Default Re: (80884)
we use the z10 girdle/aebs main studs on steves car, on my car there is an oem gsr girdle/oem main bolts, just because thats what i had, and didnt have $ to upgrade it. GE main girdles look nice too, but i havent used one of theirs yet. i like the z10 girdle because you can dowl it, but i dont think that is 100% neccessary. z10's also has some machining done to it, that i dont think other girdles have.
Old Aug 13, 2007 | 06:02 AM
80884's Avatar
Is there much difference between an oem girdle (new) and an aftermarket one? How good do the oem girdles work?
Anyone know the best place to pick up a girdle, like vendors or people on here. I keep coming up with some KMS when i search for girdles.
Old Aug 13, 2007 | 06:25 AM
tony1's Avatar
Default Re: (80884)
I run and oem gsr girdle and oem main bolts in my race car.
Old Aug 13, 2007 | 06:31 AM
80884's Avatar
Default Re: (tony1)
wow, ok, that makes two cars that I know of that make lots of power and like to rev running the oem. Maybe I'll just get the oem one and be done.
torr
May 13, 2016 04:34 AM
AssPenny
Mar 20, 2014 07:16 PM
aavtec
34
Feb 17, 2013 09:52 AM
JDogg
Dec 2, 2006 11:46 AM
baonest1
Oct 25, 2002 11:16 PM
