Getting weird boost cut after new engine build
Old Apr 15, 2007 | 11:53 PM
Turbo EH2's Avatar
* B A N N E D *
Default Getting weird boost cut after new engine build
Heres the situation.. car ran on a manual boost controller. was tuned to 11 psi. Well something happened to the block which we had to replace all the internals too a new block because a bolt stripped. COmpression and pistons and rods etc are still exactly the same in the new set up, however we hooked up an AVCR to it now. Now whenever we try to up the boost it wont go past 9lbs.. It feels like its just hitting boost cut. It cant be the AVCR because when its running off the wastegate with the avcr setting off it will run only at 6lbs... Any help would be appreciated
Old Apr 16, 2007 | 08:47 AM
Turbo EH2's Avatar
* B A N N E D *
Default Re: Getting weird boost cut after new engine build (Turbo EH2)
bump
Old Apr 16, 2007 | 11:18 AM
Turbo-Honda's Avatar
What the spring rate on your wastegate?? 6psi? If you were tuned up to 11psi, why dont you just buy 11psi spring and see if it was the boost control or something else.
If you still want to mess around with the engine, then check for boost leak, check connectors and clamps from turbo to TB. Check for gasket leak. Turbo gasket, manifold gasket, check for wastegate gasket too. Bolts on mine get loose all the time at 18psi, so check there. See if your vacuum line on the boost control hook up correctly or not.
Then again, if all checked and nothing seem wrong, I would just get 11psi spring and watch your a/f ratio to make sure everything good up to 11psi. Dont just guess, wideband pretty cheap these days; buy it, use it and have fun driving.
Old Apr 16, 2007 | 01:35 PM
mrbsponge's Avatar
sounds like you AVCR pressure pick up source is later or located after the MAP sensor and the map sensor is seeing more boost then the AVCR
Old Apr 17, 2007 | 12:52 AM
Turbo EH2's Avatar
* B A N N E D *
Default Re: (mrbsponge)
Dont know what it was... was **** about the solenoid so i replaced it and tuned today to 16lbs. Thanks for the help however.. Im guessing it was just a bad solenoid
turbo-crx
Jan 24, 2009 09:06 AM
ldanphanl
Aug 23, 2005 05:31 PM
RFd15bhatch
Jun 1, 2005 03:35 PM
n1neb4ll
Jul 30, 2003 08:07 AM
boosted hybrid
Nov 3, 2002 06:13 PM
