Getting frusterated!!!
Old Feb 15, 2009 | 07:51 AM
crxlifer21's Avatar
Default Getting frusterated!!!
So I got my new turbo on, redid the cam timing because I had the head off and added a catch can. I have my catch can ran from the stock box that the pcv valve plugged up to then for a vac source I tapped into the intake. The car wont run with the vac line plugged up to the intake. As soon as I unplug it it runs. Also I am getting quite a bit of blowby out of the valvecover and out of the hose that goes to the stock pcv box. I deleted the stock pcv valve in my setup. Do I really have to have a pcv valve in line with the intake and catchcan or not? Thanks
Old Feb 15, 2009 | 08:21 AM
b20turbojason's Avatar
Default Re: Getting frusterated!!!
i had this problem when i first set up my turbo. except i was getting alot of smoke from the turbo. it was cause i hooked up the catch can wrong. and if i remember right i did it like you. i ended up just running a hose from my valve cover to the catch can. and left the pcv like stock.
Old Feb 15, 2009 | 08:43 AM
crxlifer21's Avatar
Okay well I already deleted the stock system. So where do I go from there? Can I tap the line from the black box and the valve cover to the can and then just run a filter on the can???
Old Feb 15, 2009 | 09:32 AM
turbo97coupe's Avatar
https://honda-tech.com/forums/showth...=684673&page=2
that thread should answer all your questions with the diagrams
SFlCrx
Apr 15, 2012 03:02 PM
photec2
Nov 16, 2006 04:39 PM
mike93boost
Jan 31, 2006 07:28 PM
Ek00fbp
Nov 26, 2003 04:45 PM
d15b7racer
Aug 8, 2003 11:15 PM
