GE sleeves, stepped deck, o-ring? What are you guys using?
What are you guys with aftermarket sleeves using? Right now I have a GE sleeved h22 block and ge/oem cut head gasket. The bore is 89mm. I believe it is stepped deck already, but should I add o-rings or am i going to be ok? I plan to run as much boost as 92octane gas and a t3/t4 can support
Re: GE sleeves, stepped deck, o-ring? What are you guys using? (Wo-Nelly)
Step decked GE sleeves here. Just make sure bith surfaces are flat, use some copper spray and torque the head bolts correctly.
-Ryan
-Ryan
Re: GE sleeves, stepped deck, o-ring? What are you guys using? (Kwuaymaikrup)
how many psi are you running? From what I've heard, with higher psi 20+, you should use o-rings. Is that true?
im not 100% sure but when i got my block back from GE with the o ring set up they told me not to use Cometic headgasket. I used OEM headgasket with o ring boostin at 15psi and 75 shot of nitrous
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wo-Nelly »</TD></TR><TR><TD CLASS="quote">how many psi are you running? From what I've heard, with higher psi 20+, you should use o-rings. Is that true?</TD></TR></TABLE>
Haven't ran it yet but I will be boosting 28psi. There are quite a few people running step decks with no O-rings that have no problems. Do a quick search under my name and there is a post about this that I made. It will contain all your answers as it did for me
RICE POLICE SIP
04-22-2004 12:41 PM
