which gasket?
Old Mar 31, 2007 | 10:51 AM
teddy_dc2's Avatar
Default which gasket?
this is the main reason i'm loosing power. big *** leak out the back of the mainfold and turbine inlet as you can see. (and yes the turbo was bolted up good, just over time the gasket failed) to the left i have two gaskets, a kinda aluminum paper one and a stainless steel crush one, which one is better? (i never used the aluminum paper one before)
Old Mar 31, 2007 | 10:59 AM
shauniewalnuts's Avatar
Default Re: which gasket? (teddy_dc2)
stainless crushed... it wont burn or blow apart
Old Mar 31, 2007 | 11:19 AM
EJ1 wilcox's Avatar
Default Re: which gasket? (shauniewalnuts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shauniewalnuts &raquo;</TD></TR><TR><TD CLASS="quote">stainless crushed... it wont burn or blow apart</TD></TR></TABLE>
That's what I always use, I've never had any issues.
You might also want to check and make sure your flanges aren't warped at all, slight warpage could have caused that leak.
Old Mar 31, 2007 | 11:31 AM
teddy_dc2's Avatar
the manifolds are pretty much brand new (500-800miles) and the turbo has about 2k, i'll check for warps.
Old Mar 31, 2007 | 12:15 PM
inspyral's Avatar
Never had a problem with the stamped steel ones. I've actually been reusing the same one for several years. Usually that connection doesn't need a gasket, but I just run one to be safe. If you're getting that big of a leak, your flanges may be warped, or your manifold flange wasn't machined flat after welding.
Old Mar 31, 2007 | 12:50 PM
a1320addict's Avatar
Default Re: (inspyral)
What type of manifold?
Theoretically you shouldn't even need to use a gasket between the turbo and manifold flanges, as both flanges should be machined perfectly flat.
Old Mar 31, 2007 | 03:10 PM
Default Re: (a1320addict)
just like the head and the block right?
Old Mar 31, 2007 | 03:46 PM
93supercoupe's Avatar
Default Re: (shauniewalnuts)
not like the head and the block
Block has iron sleeves and manifolds shoulndt need gaskets.
Old Mar 31, 2007 | 04:51 PM
SPOOLINmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shauniewalnuts &raquo;</TD></TR><TR><TD CLASS="quote">just like the head and the block right?
lol tons of people dont use a gasket there, i didnt for a long time and it doesnt leak. I do now for the hell of it because i have them.
Old Mar 31, 2007 | 05:02 PM
Default Re: (SPOOLINmatt)
Two flanges are not "just like a head and block". I've, as well as many other people, have and haven't used gaskets and there have been no bad results.
Old Mar 31, 2007 | 05:15 PM
teddy_dc2's Avatar
i replace them everytime with the stamped gasket but this was the first time i had a leak out the back and don't really know why. they're rld mani's and a turbonetic t3/t4. perhaps i didn't tighten them evenly? i replaced it today, hopefully it doesn't do the same thing. too bad it's rainning so i can finish it off with a test drive.
Old Apr 1, 2007 | 09:29 AM
Default Re: (teddy_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">Two flanges are not "just like a head and block". I've, as well as many other people, have and haven't used gaskets and there have been no bad results.</TD></TR></TABLE>
i was ******* with you guys, i guess no one caught on
Old Apr 1, 2007 | 04:31 PM
teddy_dc2's Avatar
now that the leak is taken care or, it's like fuel cutting on me at around 4000rpm. i've been running this crome pro base map for two weeks and was fine, then on one hot day took it for a spin and it felt weak as hell. pulls up to 4000 and then stalls and boggs for a few seconds still slowly going up in rpm up to about vtec and then pulls good after that. what should i look for? sounds like mis firing or something, it's raining again and i'll deal with it tomorrow.
Old Apr 1, 2007 | 06:06 PM
maybe sinces its raining you got water in your dizzy cap somehow.... Coil maybe? ICM?
Old Apr 1, 2007 | 07:01 PM
OMG B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">now that the leak is taken care or, it's like fuel cutting on me at around 4000rpm. i've been running this crome pro base map for two weeks and was fine, then on one hot day took it for a spin and it felt weak as hell. pulls up to 4000 and then stalls and boggs for a few seconds still slowly going up in rpm up to about vtec and then pulls good after that. what should i look for? sounds like mis firing or something, it's raining again and i'll deal with it tomorrow.</TD></TR></TABLE>
Get a real tune.
Old Apr 1, 2007 | 07:04 PM
teddy_dc2's Avatar
true that but right now i don't have that kinda money throwing around anymore. i don't understand why it was running perfect one night, you drive it the next day and it goes into ****. the only thing i did the following day was install my cambers.
Old Apr 1, 2007 | 07:21 PM
HamiltonRex's Avatar
i never use any gaskets for my exhaust parts, ive always used the RVT red silicone stuff, works great. even says on the package designed for turbo 4 cylinders
95dc2teg
Jul 17, 2006 01:26 PM
ssrcx94
Dec 18, 2005 10:05 AM
Mario.
Jul 3, 2005 07:17 PM
kabaroo
Apr 8, 2004 11:16 AM
4-banging
Mar 15, 2004 12:03 PM
