Fully built turbo LSvtec questions....
ok, i have some questions. planning on building up an ls vtec for turbo. what are some of your setups...?
this is what im thinking...
LS block and crank - have
b16 head - have
golden eagle conversion kit
81mm 10:1 forged pistons - any ideas?
forged rods with bolts - any ideas?
oem bearings
b16 water pump - have
b16 oil pump - have
cometic head gasket for boost
arp head studs - have
cams - any ideas?
valve spring - any ideas?
b16 intake manifold - have
450cc injectors - have
t3/t4 60 trim - have a t3 super 60 from last year but ill upgrade
uberdata - have
b16 tranny with quaife lsd - have
underdrive pully with no ac or PS
manifold, intercooler etc - have already from last year.
how much boost can i run safly? i want to make 300whp and rev to 8000. possible? and what if i were crazy and want to make 400whp? what would i need to upgrade besides injectors?
b16 head - have
oem bearings
b16 oil pump - have
cams - any ideas?
uberdata - have
https://honda-tech.com/zerothread?id=1509557
would recommend that you bore it out to 81.5mm
you will also need bigger injectors like 750cc for 400+
will the crank be balance?
mine.....
Golden Eagle H-D Sleeved B18a
84mm
JE 9.0:1 forged
Eagle H-Beams
Step decked and o-ringed
ARP Head Studs
OEM Honda CRV head gasket
Golden Eagle LS/VTEC conversion Kit
'98 GSR Head
JDM ITR cams
AEBS intake mani
BBK 70mm throttle body
AEM fuel Rail
1000cc precision injectors
all oem bearings and gaskets
type-r oil pump
type-r water pump
Eaqual length ramhorn
t3/to4e
35mm Turbonetics evolution wastegate
2.5" I/C piping
24x18x3 FMIC
hondata s200b
gsr trans
clutchmasters 8lb flywheel
clutchmasters 4 puck FX500
sounds like you are on the right track to the power you want, you may need bigger injectors, and walbro 255 pump
84mm
JE 9.0:1 forged
Eagle H-Beams
ARP Head Studs
'98 GSR Head
JDM ITR cams
AEBS intake mani
AEM fuel Rail
type-r oil pump
type-r water pump
t3/to4e
2.5" I/C piping
24x18x3 FMIC
hondata s200b
gsr trans
yeah i have a 255 and ill be getting larger injectors. probably 700cc RC's. what kinda of pistons and rods should i get? will i be able to make 300hp with the stock b16 head?
