Full-Race ball bearing stage 1 kit
Is it worth buying this kit if i am only going to run 6-8psi on a stock gsr motor?
Also what thickness headgasket do you suggest i get to help lower compression? i think standard is .030" so should i get .040"?
Re: Full-Race ball bearing stage 1 kit (WalkerGSR1)
yes, You will want to upgrade after awhile so thats a good kit to go with due to you will only need to upgrade the turbo
and stock headgasket will do fine for only 6-8psi
