fuel pressure with JRSC
where should my fuel pressure be at idle with a jrsc @ 6psi?
i also have head work done, i was thinking 50 psi at idle i have a walbro 255lph fuel pump also |
Re: fuel pressure with JRSC (hondaeg8)
Stock. You won't need large enough injectors for 6psi to warrant raising your fuel pressure.
Re: fuel pressure with JRSC (EnzoSpeed)
at stock psi fuel pressure, my electrodes on the plugs were pretty white.
i did about 3 pulls and then checked the plugs. |
If you are running lean, fooling with your fuel pressure isn't going to solve your problem. You need to adjust your injector duty cycle. Oh wait, you aren't using an FMU are you...
for right now.. yeah.. fmu with stock injectors. i have some 310cc injectors, but not using them.
i just put the kit on , so i used everything it came with ecept the injectors. |
so for stock injectors, the stock fuel pressure should be kept, correct?
so it would be ~42psi at idle with hose on . |
