how to hook up
Old Jun 5, 2003 | 03:14 AM
wanttorace's Avatar
Default how to hook up
i have a fmu i was wondering if somone had a diagram that i could use so i know where to hook up the feul lines thanks
Old Jun 5, 2003 | 06:28 AM
PrecisionH23a's Avatar
Default Re: how to hook up (jjd493925)
i dont have a diagram but i have a little write up i did on my site that i did a long time ago:
http://people.clemson.edu/~ave...l.htm
edit:
from import parts.com
"Remove factory return line from factory fuel pressure regulator (located on the fuel rail). Secure factory return line to boost dependent fuel pressure regulator on the fitting labeled "OUT". Connect the fuel line on the boost dependent regulator to the factory fuel pressure regulator. Secure the boost dependent regulator to the strut tower. Cut the factory vacuum line that goes to the stock fuel pressure regulator. Connect the boost dependent regulator to the vacuum line using a t-connector. Reconnect battery and start engine. Make sure there are no fuel leaks. Disconnect the negative terminal of the battery.
97mm_EH3
Apr 12, 2011 05:31 AM
nd94cx
Sep 16, 2004 07:03 AM
blackdelsolsi
Feb 4, 2003 07:08 PM
IgniteTeg
May 29, 2002 11:08 PM
