Fuel Mangagement for 9 psi
Revhard stage 2 on a b16, running max 9 psi. Is it necessary to change my fuel mangement system or will the vortech fmu do fine? I don't want to increase boost. Thanks.
Re: Fuel Mangagement for 9 psi (Accord94DX)
SMC and DSM injectors are going to be the least expensive option. Your going to have retarded high fuel pressure at 9psi with an FMU (probably a 12:1 FMU..??) If sell the FMU and missing link, you'll probably only have a $50 out of pocket expense for the new setup.
Good luck!
Good luck!
Re: Fuel Mangagement for 9 psi (import_racer)
If I change my fuel management system, I have to get rid of the fmu and missing link?
Re: Fuel Mangagement for 9 psi (b18b98)
I have no one to tune it here in Winnipeg, Canada. If I get a hondata, do I have to remove the fmu? How about the efi pms?
