are fuel lines a must to change for 450hp?
i have a 92hb ls v-tec boostin,at the most i want 450hp at high boost with probably 110 octane. set up is pretty much done full-race kit with 60-1 turbo and all the goodies. motor is not sleeved,but will have a block guard,do i need to change the fuel lines.
Re: are fuel lines a must to change for 450hp? (PrecisionH23a)
isnt there one that goes all the way to the gas tank? if so thats the one i have to change?
Re: are fuel lines a must to change for 450hp? (PBOOSTIN)
i made 400whp on stock lines and 255intank and 756cc injectors and stock reg
but am looking to make more power now so now am putting in a sump on the stock tank and running a weldon inline fuel pump and -8 return and feed line and a adju reg so i can turn up my fuel psi to make my 750's act like 900cc's
but there a right many people that has made 500whp on stock lines
Re: are fuel lines a must to change for 450hp? (DLB1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 »</TD></TR><TR><TD CLASS="quote">but am looking to make more power now so now am putting in a sump on the stock tank and running a weldon inline fuel pump and -8 return and feed line and a adju reg so i can turn up my fuel psi to make my 750's act like 900cc's
but there a right many people that has made 500whp on stock lines </TD></TR></TABLE>
You are so ghetto
There have been guys out there to crank out 500whp on stock lines, but I always like to do it right the first time rather then chancing my luck.
You are so ghetto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 »</TD></TR><TR><TD CLASS="quote">i made 400whp on stock lines and 255intank and 756cc injectors and stock reg
I made 540whp and 400lbs.trq. on stock lines. But i'm thinking of changing them to straight lines from -8 inlet and -6 return.
