FTL with uberdata
Just set the boost cut, boost resume and other stuff would don't need to the same rpm as your fuel cut, that way it will never be enable while driving or racing.
so if redline is ex: 8200 set ftl cut to 4500 ftl resume to 4400 mph at 14, and boost cut, boost resume and others at 8200.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Von Dutch »</TD></TR><TR><TD CLASS="quote">Just set the boost cut, boost resume and other stuff would don't need to the same rpm as your fuel cut, that way it will never be enable while driving or racing.
so if redline is ex: 8200 set ftl cut to 4500 ftl resume to 4400 mph at 14, and boost cut, boost resume and others at 8200. </TD></TR></TABLE>
do this. no other suggestions needed. why wouldn't you use the boostcut though?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2muchPSI »</TD></TR><TR><TD CLASS="quote">I'm pretty sure yo u need a GM solenoid to use the boost cute.</TD></TR></TABLE>
uhhhhh......
no.
uhhhhh......
no.
i'm not sure what the boost "cute" is. the solenoid is used for boost CONTROLL not boost cut.
Apex'i AVCR solenoid works..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">
uhhhhh......
no.</TD></TR></TABLE>
Nope, you're right. You don't.
On the other hand, with a stock MAP sensor, you can only set the boost cut to 11.2 psi. That's almost useless in most setup I deal with.
uhhhhh......
So it's like hitting the limiter, no controllers needed.
