FTL with uberdata
Old Apr 20, 2004 | 07:58 PM
scatuli's Avatar
Default FTL with uberdata
i was wondering how you disable the boost cut i you want to use the FTL.
thanks chris
Old Apr 21, 2004 | 04:52 AM
.RAven's Avatar
Default Re: FTL with uberdata (scatuli)
Just set the boost cut, boost resume and other stuff would don't need to the same rpm as your fuel cut, that way it will never be enable while driving or racing.
so if redline is ex: 8200 set ftl cut to 4500 ftl resume to 4400 mph at 14, and boost cut, boost resume and others at 8200.
Old Apr 21, 2004 | 03:55 PM
scatuli's Avatar
Default Re: FTL with uberdata (Von Dutch)
bump for any other suggestions
Old Apr 21, 2004 | 04:13 PM
5STAR3's Avatar
just set the boost cut at 100psi.
and or set the rpm cut/resume above what you will ever rev.
if you cant figure this stuff out, you shouldnt be using uberdata
Old Apr 21, 2004 | 05:04 PM
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Von Dutch &raquo;</TD></TR><TR><TD CLASS="quote">Just set the boost cut, boost resume and other stuff would don't need to the same rpm as your fuel cut, that way it will never be enable while driving or racing.
so if redline is ex: 8200 set ftl cut to 4500 ftl resume to 4400 mph at 14, and boost cut, boost resume and others at 8200. </TD></TR></TABLE>
do this. no other suggestions needed. why wouldn't you use the boostcut though?
Old Apr 21, 2004 | 05:07 PM
2muchPSI's Avatar
Default Re: FTL with uberdata (ndogg)
I'm pretty sure yo u need a GM solenoid to use the boost cute.
Old Apr 21, 2004 | 05:42 PM
5STAR3's Avatar
Default Re: FTL with uberdata (2muchPSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2muchPSI &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure yo u need a GM solenoid to use the boost cute.</TD></TR></TABLE>
uhhhhh......
no.
Old Apr 21, 2004 | 07:26 PM
ndogg's Avatar
i'm not sure what the boost "cute" is. the solenoid is used for boost CONTROLL not boost cut.
Old Apr 21, 2004 | 07:43 PM
VTC_CiViC's Avatar
Apex'i AVCR solenoid works..
Old Apr 21, 2004 | 08:27 PM
raene's Avatar
It moves the redline to under your current RPM if you hit boost cute So it's like hitting the limiter, no controllers needed.
Old Apr 22, 2004 | 03:29 PM
2muchPSI's Avatar
Default Re: FTL with uberdata (raene)
learn something new everday, thanks
Old Apr 22, 2004 | 03:35 PM
kpt4321's Avatar
Default Re: FTL with uberdata (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">
uhhhhh......
no.</TD></TR></TABLE>
Nope, you're right. You don't.
On the other hand, with a stock MAP sensor, you can only set the boost cut to 11.2 psi. That's almost useless in most setup I deal with.
h2b_sedan
Engine Management and Tuning
Nov 29, 2009 05:45 PM
turbo boost
May 6, 2008 04:07 PM
ACrite3404
Sep 23, 2007 01:28 PM
turbo boost
Oct 24, 2006 02:44 PM
311
Jul 12, 2002 01:46 PM
