Freaking Vac. Lines
Old Jun 17, 2003 | 11:15 AM
ion_four's Avatar
Default Freaking Vac. Lines
I, like alot of people, am fed up with vacuum lines and leaks. My car is idling very roughly right now, only pulling about 12-14 in. of vac. after I took out my 6btm (uses a vac. line) yesterday. I obviously have a leak, but the question is...
Does anyone have any ideas on a better vacuum system? Like, a particular type of line/fitting (could go AN-?, but SPENDY!) or what about those Golden Eagle Distribution blocks (similar to those found on Fords )? What do high boost (30+psi) cars do for lines?
Right now I am using regular line with plastic T's, zipties, clamps and even glue in an attempt to make a perfect seal...which I don't have...
Old Jun 17, 2003 | 11:23 AM
GraphiteAccord's Avatar
Default Re: Freaking Vac. Lines (ion_four)
McMaster Carr.....
Old Jun 17, 2003 | 10:01 PM
ion_four's Avatar
Default Re: Freaking Vac. Lines (GraphiteAccord)
Alright, so what is that neat-o thing called or a part #? Their site is HUGE!!!
::EDIT:: Obviously I post that and then find them...they're "manifolds" and you can get one with 6 outlets, black anodized, 1"x1"x4 3/4" for $15 and change. I think I am sold.
what size is yours Graphite?
Old Jun 17, 2003 | 10:09 PM
b18cx's Avatar
another option, if you have the time.
Simple tap on the back of the manifold. Will not leak!! Very clean. Just add as many as you need.
SiR Kid's Avatar
New User
Vacuum Tree/Vacuum Log/Vacuum Distribution Block.
BTW, thanks for the "props" for the Ford thing, that was me.
Old Jun 17, 2003 | 11:41 PM
Kwuaymaikrup's Avatar
Default Re: Freaking Vac. Lines (b18cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx &raquo;</TD></TR><TR><TD CLASS="quote">another option, if you have the time.
Simple tap on the back of the manifold. Will not leak!! Very clean. Just add as many as you need.</TD></TR></TABLE> Exactly what I did
-Ryan
Old Jun 22, 2003 | 02:27 PM
ion_four's Avatar
Default Re: Freaking Vac. Lines (SiR Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">Vacuum Tree/Vacuum Log/Vacuum Distribution Block.
BTW, thanks for the "props" for the Ford thing, that was me. </TD></TR></TABLE>
yeah, that was a good find man. I've seen them in junkyards, since, but it seems like alot of the nipples are HUGE, so I'm probably going to go with the Mcmaster-carr, however, I'm going to call some hydraulic/air-fitting shops in town and see if I can't pick one up cheaper/quicker.
I don't really want to tap my intake manny because I don't plan on taking it off anytime soon and don't want to open that can of worms since I'm sans garage and beater right now...
Old Jun 22, 2003 | 06:02 PM
B18Flip's Avatar
What did you use to do that??
Old Jun 22, 2003 | 06:33 PM
AVATAR's Avatar
Default Re: Freaking Vac. Lines (B18Flip)
Of course there is this bad boy.
Here's the link on it. https://honda-tech.com/zerothread?id=384765
Old Jun 23, 2003 | 08:47 AM
ion_four's Avatar
Default Re: Freaking Vac. Lines (AVATAR)
That seems to be the same thing you can buy from http://www.Mcmaster.com, but there it's only $15.99, as opposed to $50 for that neat Logo
Old Jun 23, 2003 | 10:21 AM
SiR Kid's Avatar
New User
HAHAHA. Looks like you've got the one bolt tightened to hell and back holding your IAC to the back of the manifold as well, huh?
Old Jun 23, 2003 | 11:38 AM
arsenaldragster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four &raquo;</TD></TR><TR><TD CLASS="quote">Alright, so what is that neat-o thing called or a part #? Their site is HUGE!!!
Old Jun 23, 2003 | 01:14 PM
ion_four's Avatar
Default Re: Freaking Vac. Lines (arsenaldragster)
They call it a manifold. This looks like the one that graphite has; Black anodized aluminum, 6 ports, about 1" wide with NPT threading.
5469K151 $15.66
Probably going to order one this evening. It'll look spiffy!
Old Jun 23, 2003 | 01:20 PM
DC2R714's Avatar
What fittings do you need with that thing. 1/4" or 1/8"?
Old Jun 23, 2003 | 02:47 PM
ion_four's Avatar
Default Re: Freaking Vac. Lines (DC2R714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">What fittings do you need with that thing. 1/4" or 1/8"?</TD></TR></TABLE>
You got me. Looks like 1/4", but either way they're NPT, so you can get them at homedepot.
::EDIT::
Kind of related; what does everyone use to secure their lines? Clamps(pinch or screw?), zip-ties?
Old Jun 24, 2003 | 08:11 AM
b18cx's Avatar
To be very honest with you guys, I dont remember what sizt they were. I just went into Lowes with a piece of vac. line, found a fitting that worked, then walked over to the tap and die set ect........ You get the piont. Works GREAT and most people think its factory.
And for the IAC and one bolt???? I have a Skunk mani on a GSR. The mani comes with BOTH sets of holes for any IAC. I do have 2 bolt there and they are tightened to factory specs.
kyden
Sep 16, 2009 09:11 AM
crazyimport
May 22, 2006 06:18 PM
Justin Olson
Nov 20, 2005 08:05 PM
BlueShadow
Oct 26, 2005 11:40 AM
275Performance
Feb 11, 2004 01:06 PM
