fmu question
Old Jun 16, 2004 | 06:04 PM
URBAN TANK's Avatar
Default fmu question
Ok i have a probe gt and was going to turbo it learned everything about how to turbo the gt but i was shopping around and discoverd that it is hella cheaper to buil a hatch always wanted one anyway so i sold the probe and going to b20 turbo the hatch and was wondering if i need to use a fmu because it does not look like any one else uses one
Old Jun 16, 2004 | 07:35 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: fmu question (b204d)
there are a few ways to get the needed fuel volume for a boosted car. the fmu is a way of doing that by forcing more fuel through the injector via higher pressure. other ways are secondary injectors, or means of engine management.
Old Jun 17, 2004 | 05:23 PM
URBAN TANK's Avatar
Default Re: fmu question (boostedcivicsir)
Ok but I know that but do u have to use one on a bseries motor because u do on the klo3 motor
Old Jun 17, 2004 | 05:26 PM
DaX's Avatar
DaX
Loved
Community Favorite
For low boost applications, and FMU may be desirable - it's cheap, easy to install, and not very complicated. Once you surpass about 7psi of boost though, the FMU setup can stop working so well. This is why most people opt for an EMS like AEM, Uberdata, Hondata, Mega Squirt, you name it...something that allows you to acces and change the fuel and ignition tables of the ECU, instead of fooling the ECU into not seeing boost.
Old Jun 17, 2004 | 05:40 PM
EKB18BPR3's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">For low boost applications, and FMU may be desirable - it's cheap, easy to install, and not very complicated. Once you surpass about 7psi of boost though, the FMU setup can stop working so well. This is why most people opt for an EMS like AEM, Uberdata, Hondata, Mega Squirt, you name it...something that allows you to acces and change the fuel and ignition tables of the ECU, instead of fooling the ECU into not seeing boost.</TD></TR></TABLE>
DaX's avatar always cracks me up...
EG_GSR
Jan 8, 2007 11:49 AM
Turboredteg
Jan 28, 2005 06:38 AM
kovert
Aug 17, 2004 09:58 AM
alfee
Nov 4, 2003 09:05 PM
