Flutter sound?
Old Feb 4, 2003 | 10:21 AM
boosted6thgen's Avatar
Default Flutter sound?
I have the greddy turbo kit with a Type S bov on my 97 civic Ex. When I build up to zero vacuum and then into boost and let off the gas, the turbo or bov is making a flutter sound while blowing off(similar to the drag turbo shutter). I cant decide if its bov flutter or compressor surge. I've loosened up my bov quite a bit, but it still does it. The car is running good and I dont feel anything funny in the peddle though. Is this normal and ok, or is there a problem that needs to be looked at? thanks
Old Feb 4, 2003 | 10:31 AM
KC GSR's Avatar
Default Re: Flutter sound? (boosted6thgen)
I have the same problem with my type s too...i even loosened mine all the way and it still fluttered a little bit.
Old Feb 4, 2003 | 12:23 PM
b18b98's Avatar
Default Re: Flutter sound? (KC GSR)
how do you have your vac lines setup? Sometimes when you have to many things Tee'd into one source it causes the flutter.
Old Feb 4, 2003 | 12:42 PM
johnisenglish's Avatar
My BOVwill flutter until the engine gets up to operating temperature... I've never quite figured that one out. This is at low to negative boost though (low temp boosting = bad)
Try giving yours a dedicated vaccum line from the manifold though
[Modified by johnisenglish, 4:42 PM 2/4/2003]
Old Feb 4, 2003 | 03:19 PM
BoostedD15B7's Avatar
Default Re: Flutter sound? (johnisenglish)
The greddy Type S will flutter under lower boost levels and get a higher pitch squeak at high boost level......It supposed to do that.
R6E6I6D
Jul 18, 2008 01:44 PM
Jayboy
May 12, 2005 10:57 PM
buttsneeze
Mar 17, 2005 11:07 PM
pip9
Apr 18, 2004 07:34 AM
boosted6thgen
Feb 4, 2003 11:53 AM
