Flutter sound?
Old Feb 4, 2003 | 10:10 AM
boosted6thgen's Avatar
Default Flutter sound?
I have the greddy turbo kit with a Type S bov on my 97 civic Ex. When I build up to zero vacuum and then into boost and let off the gas, the turbo or bov is making a flutter sound while blowing off(similar to the drag turbo shutter). I cant decide if its bov flutter or compressor surge. I've loosened up my bov quite a bit, but it still does it. The car is running good and I dont feel anything funny in the peddle though. Is this normal and ok, or is there a problem that needs to be looked at? thanks
Old Feb 4, 2003 | 11:53 AM
wickedEFguy's Avatar
Default Re: Flutter sound? (boosted6thgen)
my friend had the same problem with his the exact same BOV on his DSm. What I would do is check the vacuum lines for any leaks or holes and just replace them. One other thing is that you might have a bad spring in the BOV. How much boost are you pushing anyways?
holsetcivic
Apr 21, 2009 08:49 PM
buttsneeze
Mar 17, 2005 11:07 PM
desert eagle
Jan 20, 2005 07:10 PM
CRXdan
Dec 11, 2004 10:38 PM
boosted6thgen
Feb 4, 2003 03:19 PM
