Flex pipe and IAT...did search
Old Sep 30, 2002 | 06:46 PM
_Endless_'s Avatar
Default Flex pipe and IAT...did search
first, do you turbo guys use a flex pipe somewhere between the downpipe and exhaust pipe? it seems not all of you are using one, won't that create stress once the engine is on?
lastly, where is the proper way to put the IAT sensor? is it on pipe that is bolted on the t/b where the bov is also located? OR do you put it after the air filter and before the compressor? OR is there any other place? i did search and found out that people have different ways to do it and no one mentioned the proper place to put it.
Old Sep 30, 2002 | 08:01 PM
tony1's Avatar
Default Re: Flex pipe and IAT...did search (_Endless_)
It's going to be more accurate right before the tb, but on the new civics most people put it in the intake to the turbo since the sensor just presses in. You will probably blow it out of a charge pipe. And yes, you do need to either use a flexpipe or the factory donut gasket and flange.
Old Sep 30, 2002 | 08:28 PM
b00stedsi's Avatar
Default Re: Flex pipe and IAT...did search (tony1)
Put the IAT on your manifold. On the type r the IAT is in the manifold. There is a way but i dont remember if there were specific parts to do this for say to a b16a2. some body help..
Old Sep 30, 2002 | 09:13 PM
inspyral's Avatar
Default Re: Flex pipe and IAT...did search (turkish)
I put min in the charge piping before the TB with some silicone sealant to keep it from blowing out.
Ash J. Williams
Nov 2, 2013 04:17 PM
r0yal
Welding / Fabrication
Apr 19, 2006 07:03 PM
DB1_559
Sep 21, 2005 07:33 PM
boostincoupe
Jan 28, 2005 06:20 PM
Teg4e
May 29, 2002 10:41 AM
