Flex Pipe or Test Pipe for Turbo Exhaust Setup?
Old May 29, 2002 | 10:13 AM
Teg4e's Avatar
Default Flex Pipe or Test Pipe for Turbo Exhaust Setup?
Soon I'll need a shop to fit the DRAG downpipe to something to fit my 3" Thermal exhuast. I'm not using a cat, so what should I have them attach in place?
Old May 29, 2002 | 10:22 AM
Flamenco-T's Avatar
Default Re: Flex Pipe or Test Pipe for Turbo Exhaust Setup? (94hondahybrid)
you an use either way, if you use a flex pipe, just weld a 2.5" to 3" flare to the flex pipe and weld the regular 3" 3 bolts flange to it to connect it to the cat-back
if you;re using a test pipe, just make sure you use the spring loaded bolts to compensate for the jerking, so that it'll have less stress on the manifold...
Old May 29, 2002 | 10:38 AM
LowGSR01's Avatar
Default Re: Flex Pipe or Test Pipe for Turbo Exhaust Setup? (Teg4e)
What about a 3" Hi-Flow Cat?
Old May 29, 2002 | 10:41 AM
quikrpm'z's Avatar
Default Re: Flex Pipe or Test Pipe for Turbo Exhaust Setup? (Flamenco-t)
does anyone have any problem with the flex pipe whistling?
also why not just get a 2.5" flex pipe weld it to the downpipe retaining the downpipes flange? Just remove the same size of piping as the length of the flex pipe.
$amGD3
Feb 9, 2011 11:31 AM
B16CRXT
Mar 14, 2005 02:34 PM
tonezilla
Welding / Fabrication
Feb 15, 2005 07:17 AM
lanojp1
Nov 12, 2004 09:08 PM
optikal_blitz
Feb 11, 2004 10:22 AM
