:flame suite on:
Old May 19, 2006 | 03:19 PM
Tactic$'s Avatar
Default :flame suite on:
I can't believe I don't know how to do this, after all the years I've studied.
How can I check a CEL on OBDI board, when everytime I click the key back one click, the code goes away??? I can't check the code while the car is on, can I ?
Restart the car, Code gone......Right so, during decel, in gear, foot off the gas, the injectors seem to "turn on" and BAM! CEL comes back on. (only happens on decel, in gear, foot off the gas completely)
frustrated
Old May 19, 2006 | 03:25 PM
SOHC_MShue's Avatar
Default Re: :flame suite on: (Tactic$)
check it while the car is on. Wont hurt anything.
Old May 19, 2006 | 03:36 PM
Tactic$'s Avatar
****, I forgot to list the setup.
(99 si) B16 stock for the most part.
Uber
440cc inj.
3" turbo back
PLX
Street tuned.
Won't hurt to check it while the car's running?
I was afraid of burning something up.
Old May 19, 2006 | 04:04 PM
SOHC_MShue's Avatar
Default Re: (Tactic$)
nope it will be fine
Old May 19, 2006 | 04:51 PM
qfast817's Avatar
Default Re: (SOHC_MShue)
naw it wont hurt anything..
Old May 19, 2006 | 08:44 PM
leed's Avatar
Default Re: (qfast817)
With the car warmed, and throwing a CEL after a >6-7sec decel, Id put my money on it showing o2 code once you check it.
Old May 19, 2006 | 10:04 PM
SOHC_MShue's Avatar
Default Re: (leed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leed &raquo;</TD></TR><TR><TD CLASS="quote">With the car warmed, and throwing a CEL after a &gt;6-7sec decel, Id put my money on it showing o2 code once you check it. </TD></TR></TABLE>
yea very true...uberdata likes to be gay with throwing that code if you dont have the sensor hooked up and in the exhaust flow.
Old May 20, 2006 | 09:45 AM
Tactic$'s Avatar
The primary is still hooked up. I'm not using the simulation signal from the PLX. (two bungs in the DP)
The secondary O2 sensor has been removed.
I figured it was probably O2..... Thanks for your help.
slvrlude
Dec 27, 2008 02:50 PM
slob20ef
Dec 11, 2008 10:07 AM
redman223
Jul 13, 2008 01:37 PM
krisfnbs
May 23, 2008 06:42 AM
Hellz99si
Sep 18, 2002 03:05 PM
